Saltar al contenido principal
Dell Latitude E7270 Back Panel Replacement
Jacob Clement
Jacob Clement y 3 otros contribuidores
Última actualización: April 27, 2020
2 minuto
Muy fácil
Introducción
Ir al paso 1
This is this guide to remove the back panel of the Dell Latitude E7270.
In order to proceed with all manner of repairs or upgrades, the back panel is the first thing that is needed to be removed. This will be the simplest task to do throughout the whole process.
Qué necesitas
Herramientas
  1. Dell Latitude E7270 Back Panel Replacement, Back Panel: paso 1, imagen 1 de 1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Back Panel Replacement: paso 2, imagen 1 de 1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Back Panel Replacement: paso 3, imagen 1 de 1
    • Lift and remove the panel.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 22
Todo El Tiempo: 769
