Saltar al contenido principal
Dell Latitude E6520 Keyboard Replacement
Alec Weiss
Alec Weiss y 2 otros contribuidores
Última actualización: December 19, 2018
10 minuto
Fácil
Introducción
Ir al paso 1
The steps in this guide will require a JIS #0 screw driver to remove 6 screws with a head size of approximately 4.36mm and length of 3.63mm.
Qué necesitas
Herramientas
  1. Dell Latitude E6520 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Dell Latitude E6520 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
    • When the latches are unlocked, a small logo resembling an open padlock will become visible.
  2. Dell Latitude E6520 Keyboard Replacement: paso 2, imagen 1 de 2 Dell Latitude E6520 Keyboard Replacement: paso 2, imagen 2 de 2
    • Grasp the battery from the top and pull upward.
  3. Dell Latitude E6520 Keyboard Replacement, Bottom Cover: paso 3, imagen 1 de 2 Dell Latitude E6520 Keyboard Replacement, Bottom Cover: paso 3, imagen 2 de 2
    • Remove the ten 8.6 mm JIS #0 screws.
  4. Dell Latitude E6520 Keyboard Replacement: paso 4, imagen 1 de 1
    • Place fingers underneath cover and pull off the cover.
  5. Dell Latitude E6520 Keyboard Replacement, Keyboard: paso 5, imagen 1 de 3 Dell Latitude E6520 Keyboard Replacement, Keyboard: paso 5, imagen 2 de 3 Dell Latitude E6520 Keyboard Replacement, Keyboard: paso 5, imagen 3 de 3
    • Pry off the plastic keyboard trim. It is easiest to start at the bottom of the keyboard.
  6. Dell Latitude E6520 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Latitude E6520 Keyboard Replacement: paso 6, imagen 2 de 2
    • Remove the six 3.63 mm JIS #0 screws holding the keyboard in place.
  7. Dell Latitude E6520 Keyboard Replacement: paso 7, imagen 1 de 2 Dell Latitude E6520 Keyboard Replacement: paso 7, imagen 2 de 2
    • Lift the keypad up from the bottom.
    • Rest the keypad on the LCD screen for easy access during the next step.
  8. Dell Latitude E6520 Keyboard Replacement: paso 8, imagen 1 de 2 Dell Latitude E6520 Keyboard Replacement: paso 8, imagen 2 de 2
    • Peel back the tape holding the ribbon connector.
    • Disconnect the ribbon and the keyboard will be free from the laptop.
Conclusión
Alec Weiss
Miembro Desde 11/05/18
800 Reputación
8 Guías creadas
Equipo
IUPUI, Team S2-G2, Baechle Fall 2018 Miembro de IUPUI, Team S2-G2, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G2
3 Miembros
8 Guías creadas
Un comentario
Hello,
Nice instructions, could someone please tell me what are the other conector/ribbions used for in this dell e6520 under the keyboard ? any help will most appreciated.
Thanks in advance
khalidaafghany - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 54
Todo El Tiempo: 2,149
