Dell Latitude E6500 Hard Drive Replacement
Place the computer upside down on a clean, flat surface. Remove the bottom of the base assembly
Remove the four M3 x 3-mm screws (marked with an "H") that secure the hard drive
Remove the M3 x 3mm screw from the bezel and take the bezel off the hard drive.
Attach the bezel to the hard drive using the M3 x 3mm screw.
Slide the hard drive into the bay until it is fully seated
