Saltar al contenido principal
Dell Latitude E6420 Screen Replacement
Madysen Eames
Madysen Eames y otro contribuidor
Última actualización: May 23, 2018
10 minuto
Moderado
Introducción
Ir al paso 1
Laptop screens can crack or stop displaying picture. This guide will show users how to replace the screen.
Qué necesitas
Herramientas
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
  1. Dell Latitude E6420 Screen Replacement, Battery: paso 1, imagen 1 de 2 Dell Latitude E6420 Screen Replacement, Battery: paso 1, imagen 2 de 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Screen Replacement: paso 2, imagen 1 de 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Screen Replacement, Screen: paso 3, imagen 1 de 2 Dell Latitude E6420 Screen Replacement, Screen: paso 3, imagen 2 de 2
    • Open the laptop and lay it flat on your work surface.
    • Using the spudger, lift the bezel up from around the laptop screen.
  4. Dell Latitude E6420 Screen Replacement: paso 4, imagen 1 de 3 Dell Latitude E6420 Screen Replacement: paso 4, imagen 2 de 3 Dell Latitude E6420 Screen Replacement: paso 4, imagen 3 de 3
    • Using the screwdriver, remove four 5mm Phillips #0 screws from the bottom of the laptop screen.
    • Using the screwdriver, remove two 3mm Phillips #0 screws from the top of the laptop screen.
    • Lift the screen.
  5. Dell Latitude E6420 Screen Replacement: paso 5, imagen 1 de 1
    • Lift the laptop screen and flip it over to lay it on top of the keyboard.
  6. Dell Latitude E6420 Screen Replacement: paso 6, imagen 1 de 2 Dell Latitude E6420 Screen Replacement: paso 6, imagen 2 de 2
    • Remove the piece of tape from the back of the LCD cable.
  7. Dell Latitude E6420 Screen Replacement: paso 7, imagen 1 de 2 Dell Latitude E6420 Screen Replacement: paso 7, imagen 2 de 2
    • Lift the piece of tape attached to the LCD cable.
    • Once the tape has lifted, gently pull back to unplug the LCD cable.
Conclusión
9 personas más completaron esta guía.
Madysen Eames
Miembro Desde 02/27/18
1,555 Reputación
7 Guías creadas
Equipo
Un comentario
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 23
Ultimos 30 días: 30
Todo El Tiempo: 4,189
