Saltar al contenido principal
Dell Latitude E6420 Keyboard Replacement
Madysen Eames
Madysen Eames y otro contribuidor
Última actualización: May 23, 2018
15 minuto
Moderado
Introducción
Ir al paso 1
Keys can break off or stop working. This guide will show users how to replace the keyboard.
Qué necesitas
Herramientas
Ver más…
  1. Dell Latitude E6420 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Dell Latitude E6420 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Keyboard Replacement: paso 2, imagen 1 de 1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Keyboard Replacement, CD/DVD Drive: paso 3, imagen 1 de 2 Dell Latitude E6420 Keyboard Replacement, CD/DVD Drive: paso 3, imagen 2 de 2
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Keyboard Replacement: paso 4, imagen 1 de 2 Dell Latitude E6420 Keyboard Replacement: paso 4, imagen 2 de 2
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Keyboard Replacement, Backplate: paso 5, imagen 1 de 2 Dell Latitude E6420 Keyboard Replacement, Backplate: paso 5, imagen 2 de 2
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Keyboard Replacement: paso 6, imagen 1 de 2 Dell Latitude E6420 Keyboard Replacement: paso 6, imagen 2 de 2
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Keyboard Replacement, Keyboard: paso 7, imagen 1 de 3 Dell Latitude E6420 Keyboard Replacement, Keyboard: paso 7, imagen 2 de 3 Dell Latitude E6420 Keyboard Replacement, Keyboard: paso 7, imagen 3 de 3
    • Use the plastic opening tool to remove the bezel from around the keyboard.
  8. Dell Latitude E6420 Keyboard Replacement: paso 8, imagen 1 de 2 Dell Latitude E6420 Keyboard Replacement: paso 8, imagen 2 de 2
    • Using the screwdriver, remove four 3mm Phillips #0 screws from the keyboard.
  9. Dell Latitude E6420 Keyboard Replacement: paso 9, imagen 1 de 2 Dell Latitude E6420 Keyboard Replacement: paso 9, imagen 2 de 2
    • Lift the keyboard and use the spudger to disconnect the keyboard cable.
    • Gently lift the keyboard to prevent damage to the cable.
  10. Dell Latitude E6420 Keyboard Replacement: paso 10, imagen 1 de 1
    • Lift the keyboard out of the laptop.
Conclusión
3 personas más completaron esta guía.
Madysen Eames
Miembro Desde 02/27/18
1,555 Reputación
7 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 43
Todo El Tiempo: 3,499
