Dell Latitude E6420 Backplate Replacement
Introducción
Ir al paso 1The backplate can crack and expose the hardware it protects. This guide will show the user how to replace the backplate.
Qué necesitas
Herramientas
Push the tabs on the left and right of the battery out towards the edge of the case.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
4 personas más completaron esta guía.
