Saltar al contenido principal
Dell Latitude E6410 CMOS Battery Replacement
Aaron Thomas
Aaron Thomas y otro contribuidor
Última actualización: June 3, 2021
10 minuto
Moderado
Guía aportada por comunidad
Qué necesitas
Partes
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Dell Latitude E6410 CMOS Battery Replacement, Remove all external components: paso 1, imagen 1 de 1
    • Make sure you have removed all external components from your device (ie. USBs, ethernets, power cords, audio devices, SD cards, etc.)
  2. Dell Latitude E6410 CMOS Battery Replacement, Remove battery: paso 2, imagen 1 de 3 Dell Latitude E6410 CMOS Battery Replacement, Remove battery: paso 2, imagen 2 de 3 Dell Latitude E6410 CMOS Battery Replacement, Remove battery: paso 2, imagen 3 de 3
    • To remove the battery, slide the latches inward, and remove the battery from the system.
  3. Dell Latitude E6410 CMOS Battery Replacement, Remove the access panel: paso 3, imagen 1 de 3 Dell Latitude E6410 CMOS Battery Replacement, Remove the access panel: paso 3, imagen 2 de 3 Dell Latitude E6410 CMOS Battery Replacement, Remove the access panel: paso 3, imagen 3 de 3
    • To remove the access panel, use your screwdriver to remove the single screw in the center of the base. Then, slide the access panel toward the front of the system and lift it from the system.
  4. Dell Latitude E6410 CMOS Battery Replacement, Disconnect the coin-cell battery cable from the system board: paso 4, imagen 1 de 3 Dell Latitude E6410 CMOS Battery Replacement, Disconnect the coin-cell battery cable from the system board: paso 4, imagen 2 de 3 Dell Latitude E6410 CMOS Battery Replacement, Disconnect the coin-cell battery cable from the system board: paso 4, imagen 3 de 3
    • After removing the access panel, locate the coin cell battery. Then disconnect the battery cable from the system board and lift the coin-cell battery out of its socket to remove.
  5. Dell Latitude E6410 CMOS Battery Replacement, Replace battery.: paso 5, imagen 1 de 3 Dell Latitude E6410 CMOS Battery Replacement, Replace battery.: paso 5, imagen 2 de 3 Dell Latitude E6410 CMOS Battery Replacement, Replace battery.: paso 5, imagen 3 de 3
    • With your replacement battery, perform the previous steps in reverse order.
Conclusión
Una persona más ha completado esta guía.
Aaron Thomas
Miembro Desde 02/16/21
1,224 Reputación
10 Guías creadas
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
Miembros de 43
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 31
Todo El Tiempo: 1,837
