Saltar al contenido principal
Dell Latitude E6330 Speakers Replacement
Phillip Nguyen
Phillip Nguyen y 3 otros contribuidores
Última actualización: August 16, 2019
30 minuto - 1 hora
Moderado
Guía aportada por comunidad
Introducción
Ir al paso 1
In order to remove the speakers you must remove everything obstructing them. The speakers are deep within the laptop and require removal of many other components before contacting the them. In order to proceed with this guide ensure your device is turned off and unplugged.
Qué necesitas
  1. Dell Latitude E6330 Speakers Replacement, Removing Battery and Hard Drive: paso 1, imagen 1 de 2 Dell Latitude E6330 Speakers Replacement, Removing Battery and Hard Drive: paso 1, imagen 2 de 2
    • Take out the battery by pulling the tabs.
    • Unscrew 2 screws and remove the hard drive (Phillips Head 1 2.5mm x 5mm).
  2. Dell Latitude E6330 Speakers Replacement, Removing SD Card and DVD Drive: paso 2, imagen 1 de 2 Dell Latitude E6330 Speakers Replacement, Removing SD Card and DVD Drive: paso 2, imagen 2 de 2
    • Press and remove the SD card protector.
    • Press and remove the pull tab on DVD Drive.
  3. Dell Latitude E6330 Speakers Replacement, Removing the Backplate: paso 3, imagen 1 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Backplate: paso 3, imagen 2 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Backplate: paso 3, imagen 3 de 3
    • Unscrew the five screws (Phillips Head 1 2.5mm x 5mm).
    • Remove the backplate by pulling from the battery to the front.
  4. Dell Latitude E6330 Speakers Replacement, Removing the Keyboard Bezel: paso 4, imagen 1 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Keyboard Bezel: paso 4, imagen 2 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Keyboard Bezel: paso 4, imagen 3 de 3
    • Remove the track pad wire by carefully pulling up.
    • Flip the laptop over to top.
    • Remove the bezel from the keyboard by prying under the bezel and unclipping it.
    • Pull the bezel from the track pad to the screen to remove it.
    • The wire is fragile, handle with care.
  5. Dell Latitude E6330 Speakers Replacement, Keyboard and Trackpad Removal: paso 5, imagen 1 de 3 Dell Latitude E6330 Speakers Replacement, Keyboard and Trackpad Removal: paso 5, imagen 2 de 3 Dell Latitude E6330 Speakers Replacement, Keyboard and Trackpad Removal: paso 5, imagen 3 de 3
    • Unscrew the three screws (Phillips Head 1 2mm x 3mm).
    • Unclip the keyboard wire harness, then slide the wire towards the screen to remove it.
    • Unclip the trackpad wire harness, sliding the wire towards the front of the laptop to remove it.
    • The wire harnesses are fragile and may break if the user adds too much pressure.
  6. Dell Latitude E6330 Speakers Replacement, Removing LEDs and Screws: paso 6, imagen 1 de 3 Dell Latitude E6330 Speakers Replacement, Removing LEDs and Screws: paso 6, imagen 2 de 3 Dell Latitude E6330 Speakers Replacement, Removing LEDs and Screws: paso 6, imagen 3 de 3
    • Grab the wire harness and pull towards the track pad to remove it.
    • Remove the six screws (Phillips Head 1 2.5mm x 5mm).
    • Remove the two screws (Phillips Head 1 2mm x 3mm).
  7. Dell Latitude E6330 Speakers Replacement, Removing Back-Palmrest Screws: paso 7, imagen 1 de 1
    • Remove the nine screws labeled P (Phillips Head 1 2.5 x 5mm).
    • Remove the two screws (Phillips Head 1 2 x 3mm).
  8. Dell Latitude E6330 Speakers Replacement, Remove the Palmrest: paso 8, imagen 1 de 3 Dell Latitude E6330 Speakers Replacement, Remove the Palmrest: paso 8, imagen 2 de 3 Dell Latitude E6330 Speakers Replacement, Remove the Palmrest: paso 8, imagen 3 de 3
    • Insert spudger tool into crease of palmrest, prying in a downward motion.
    • Move along the edges of the palmrest, relieving all clips from laptop base.
    • Remove palmrest in a upwards motion.
  9. Dell Latitude E6330 Speakers Replacement, Removing the Speaker Wire: paso 9, imagen 1 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Speaker Wire: paso 9, imagen 2 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Speaker Wire: paso 9, imagen 3 de 3
    • Remove the four screws to the speakers (Phillips Head 1 2.5 x 7mm).
    • Remove the speaker wire harness. Pull towards the track pad to remove it.
    • the wire is fragile, pull with care.
  10. Dell Latitude E6330 Speakers Replacement, Removing the Speakers: paso 10, imagen 1 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Speakers: paso 10, imagen 2 de 3 Dell Latitude E6330 Speakers Replacement, Removing the Speakers: paso 10, imagen 3 de 3
    • Remove or move tape out of the way in order to release the wire.
    • Remove the speakers.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 946
