Saltar al contenido principal
Dell Latitude E5500 RAM Replacement
Evan Eldridge
Evan Eldridge y 2 otros contribuidores
Última actualización: December 24, 2016
10 minuto
Fácil
Guía de Estudiante Destacada
Introducción
Ir al paso 1
If the user would like to replace a faulty RAM stick or one with insufficient capacity, this guide will give step by step information on how to achieve this.
Qué necesitas
Herramientas
  1. Dell Latitude E5500 RAM Replacement, RAM: paso 1, imagen 1 de 1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 RAM Replacement: paso 2, imagen 1 de 2 Dell Latitude E5500 RAM Replacement: paso 2, imagen 2 de 2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 RAM Replacement: paso 3, imagen 1 de 1
    • The RAM sticks are located near the center of the device, and are arranged one on top of the other.
  4. Dell Latitude E5500 RAM Replacement: paso 4, imagen 1 de 2 Dell Latitude E5500 RAM Replacement: paso 4, imagen 2 de 2
    • Locate the two dislocating tabs on each side of the stick and place your fingers on the tabs.
    • Pull the tabs away from the stick to pop it out of place.
    • Notice the angle it rests at after the tabs have been opened. This is important for installation of new RAM.
    • Once the RAM stick has popped out of place, it can be gently removed.
  5. Dell Latitude E5500 RAM Replacement: paso 5, imagen 1 de 3 Dell Latitude E5500 RAM Replacement: paso 5, imagen 2 de 3 Dell Latitude E5500 RAM Replacement: paso 5, imagen 3 de 3
    • If necessary, repeat this process with the second RAM stick that lies beneath the first one.
Conclusión
To reassemble your device, install the new stick(s) and follow these instructions in reverse order.
4 personas más completaron esta guía.
Evan Eldridge
Miembro Desde 10/20/16
215 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G4
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 16
Ultimos 30 días: 27
Todo El Tiempo: 2,175
