Saltar al contenido principal
Dell Latitude E5410 Coin-Cell Battery Replacement
Dante Watson-Hardy
Dante Watson-Hardy y 2 otros contribuidores
Última actualización: June 17, 2021
3 - 5 minutos
Fácil
Guía aportada por comunidad
Qué necesitas
Partes
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Dell Latitude E5410 Coin-Cell Battery Replacement, Battery Replacement: paso 1, imagen 1 de 1
    • Have your Dell Latitude E5410 unit ready face down.
  2. Dell Latitude E5410 Coin-Cell Battery Replacement: paso 2, imagen 1 de 1
    • Use your thumb to move the tab to the right that releases the battery, while using your other hand to slide the battery out.
    • The battery will come out straight toward you.
  3. Dell Latitude E5410 Coin-Cell Battery Replacement: paso 3, imagen 1 de 1
    • Have your replacement battery ready to slide in.
  4. Dell Latitude E5410 Coin-Cell Battery Replacement, Remove the Access Panel: paso 4, imagen 1 de 2 Dell Latitude E5410 Coin-Cell Battery Replacement, Remove the Access Panel: paso 4, imagen 2 de 2
    • After removing the battery, loosen the screw that secures the access panel to the computer. Then, lift up the access panel at an angle and remove it from the computer.
  5. Dell Latitude E5410 Coin-Cell Battery Replacement, Remove the Coin-cell battery: paso 5, imagen 1 de 2 Dell Latitude E5410 Coin-Cell Battery Replacement, Remove the Coin-cell battery: paso 5, imagen 2 de 2
    • Disconnect the coin-cell battery cable from the system board.
    • Slide the coin-cell battery from its socket.
Conclusión
With you new battery, reassemble your device by performing the instructions above in reverse order.
Dante Watson-Hardy
Miembro Desde 02/16/21
199 Reputación
1 Guía escrita
Equipo
RampUP America, Inc. Miembro de RampUP America, Inc.
Community
43 Miembros
1,985 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 1,012
