Saltar al contenido principal
Dell Latitude D620 RAM Replacement
Miguel Wong
Miguel Wong y 7 otros contribuidores
Última actualización: January 28, 2014
10 minuto
Moderado
Faltan requisitos previos
Introducción
Ir al paso 1
Guide to installing new RAM modules for the Dell Latitude D620.
Qué necesitas
Herramientas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Dell Latitude D620 RAM Replacement, Keyboard: paso 1, imagen 1 de 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 RAM Replacement: paso 2, imagen 1 de 3 Dell Latitude D620 RAM Replacement: paso 2, imagen 2 de 3 Dell Latitude D620 RAM Replacement: paso 2, imagen 3 de 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 RAM Replacement: paso 3, imagen 1 de 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 RAM Replacement: paso 4, imagen 1 de 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 RAM Replacement: paso 5, imagen 1 de 2 Dell Latitude D620 RAM Replacement: paso 5, imagen 2 de 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 RAM Replacement: paso 6, imagen 1 de 2 Dell Latitude D620 RAM Replacement: paso 6, imagen 2 de 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 RAM Replacement: paso 7, imagen 1 de 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 RAM Replacement, RAM: paso 8, imagen 1 de 2 Dell Latitude D620 RAM Replacement, RAM: paso 8, imagen 2 de 2
    • With the keyboard removed, you should be able to see ram slot A.
    • Place new ram into the slot making sure it is aligned
  9. Dell Latitude D620 RAM Replacement: paso 9, imagen 1 de 1
    • Replace the keyboard by following the previous steps in reverse
    • Close the laptop, and flip it over onto its backside
  10. Dell Latitude D620 RAM Replacement: paso 10, imagen 1 de 2 Dell Latitude D620 RAM Replacement: paso 10, imagen 2 de 2
    • Loosen the screw that holds the RAM cover in place.
    • The screw cannot be fully removed since it is attached to the RAM cover.
  11. Dell Latitude D620 RAM Replacement: paso 11, imagen 1 de 2 Dell Latitude D620 RAM Replacement: paso 11, imagen 2 de 2
    • Insert new ram into slot B
Conclusión
26 personas más completaron esta guía.
Miguel Wong
Miembro Desde 04/15/10
562 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 24-35, Regan Spring 2010 Miembro de Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Miembros
4 Guías creadas
2 comentarios
If you are increasing the amount of RAM installed -> On first power on after installing the RAM, system on boot up will complain about memory size changed, and to reseat the memory. Wait for about 60 - 90 seconds, and you will receive a few additional messages about F1 to continue or F2 for Setup. Go into Setup and verify that the system sees all memory installed. If installing 2 x 2GB DDR2, max possible, 4GB. BIOS setup should report 4GB installed, of which 3.37GB usable.
Michael Erwin - Contestar
J’étais inquiet, mais en lisant votre commentaire, me voilà rassuré et j’ai donc suivi vos instructions. Ca fonctionne 2X2 GO …Merci
ppgauchard -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 40
Todo El Tiempo: 34,525
