Saltar al contenido principal
Dell Latitude D620 Hard Drive Replacement
James Martin
James Martin y otro contribuidor
Última actualización: December 13, 2016
10 minuto
Fácil
Guía aportada por comunidad
Introducción
Ir al paso 1
This is very simple compared to RAM removal on this laptop.
Qué necesitas
Herramientas
    • First, as always, power down the laptop and remove the battery., This can be done by pulling the two tabs above the battery and then simply pulling out the battery.
  1. Dell Latitude D620 Hard Drive Replacement, Unscrew the drive bay: paso 2, imagen 1 de 1
    • Now, remove the two drive screws, located in the bottom right of the laptop. These are helpfully labeled with a cylindrical hard drive icon.
  2. Dell Latitude D620 Hard Drive Replacement, Removing the drive bay: paso 3, imagen 1 de 1
    • Now, simply pull the hard drive out
  3. Dell Latitude D620 Hard Drive Replacement, Removing the drive from its cage: paso 4, imagen 1 de 1
    • Now, remove the drive from its cage by removing the single screw holding it in. See the picture for help
Conclusión
To reassemble your device, attach your drive to the bay and follow these instructions in reverse order.
5 personas más completaron esta guía.
James Martin
Miembro Desde 03/19/16
231 Reputación
1 Guía escrita
2 comentarios
can i install 1 tr wd sshd 2.5 inch on dell d620?
does it support it??
please answer my quastion.
pouranvary@gmail.com
mohammad - Contestar
can my dell d620 support 1 tr sshd?
does it support 1 tr hard?
please answer my quastion:
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 20
Ultimos 30 días: 39
Todo El Tiempo: 2,700
