Saltar al contenido principal
Dell Latitude 5480 Display Replacement
Valencia Vidrine
Valencia Vidrine y 3 otros contribuidores
Última actualización: June 18, 2024
20 minuto
Moderado
Introducción
Ir al paso 1
Users can look to this guide if they are looking to replace their screen for the Dell Latitude 5480 laptop. Screens provide visuals for users. Users will want to replace their screen if it is cracked or their screen appears black.
Qué necesitas
Partes
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Dell Latitude 5480 Display Replacement, Lower Case: paso 1, imagen 1 de 1
    • Use a Phillips screwdriver to remove the eight 5.6 mm screws that secure the lower case.
  2. Dell Latitude 5480 Display Replacement: paso 2, imagen 1 de 3 Dell Latitude 5480 Display Replacement: paso 2, imagen 2 de 3 Dell Latitude 5480 Display Replacement: paso 2, imagen 3 de 3
    • Insert an opening tool into the seam between the lower case and chassis.
    • Pry up around the perimeter of the device until the lower case fully releases.
    • Lift off the lower case.
  3. Dell Latitude 5480 Display Replacement, Battery: paso 3, imagen 1 de 2 Dell Latitude 5480 Display Replacement, Battery: paso 3, imagen 2 de 2
    • Remove the four 5.6 mm Phillips screws that secure the battery.
  4. Dell Latitude 5480 Display Replacement: paso 4, imagen 1 de 3 Dell Latitude 5480 Display Replacement: paso 4, imagen 2 de 3 Dell Latitude 5480 Display Replacement: paso 4, imagen 3 de 3
    • Lift the battery up and out of the chassis.
  5. Dell Latitude 5480 Display Replacement, Display: paso 5, imagen 1 de 3 Dell Latitude 5480 Display Replacement, Display: paso 5, imagen 2 de 3 Dell Latitude 5480 Display Replacement, Display: paso 5, imagen 3 de 3
    • Insert a plastic card between the bezel and the display.
    • Slide the plastic card beneath the entire bezel to sever the adhesive that secures the bezel.
    • Lift the bezel off of the display.
  6. Dell Latitude 5480 Display Replacement: paso 6, imagen 1 de 3 Dell Latitude 5480 Display Replacement: paso 6, imagen 2 de 3 Dell Latitude 5480 Display Replacement: paso 6, imagen 3 de 3
    • Remove the four 5.6 mm Phillips head screws, one at each corner, to release the display assembly.
    • Gently lift away the display panel and set it on top of the keyboard.
    • Take care not to strain the display assemble cable.
  7. Dell Latitude 5480 Display Replacement: paso 7, imagen 1 de 3 Dell Latitude 5480 Display Replacement: paso 7, imagen 2 de 3 Dell Latitude 5480 Display Replacement: paso 7, imagen 3 de 3
    • On the bottom of the back of the display panel, remove the tape that secures the cable connecting the screen to the base of the computer.
    • Flip up the display cable locking bar.
    • Disconnect the display connector.
    • Remove the display.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 257
