Saltar al contenido principal
Dell Latitude 5310 - The Processor Fan failed to respond correctly
Oliver Sandmaier
Oliver Sandmaier y 2 otros contribuidores
Última actualización: May 7, 2024
10 - 30 minutos
Moderado
¡Viñetas!
Guía aportada por comunidad
Introducción
Ir al paso 1
  • Here is a possible solution for fixing the error "The Processor Fan failed to respond correctly"
  • Often fans are dusted and dirty and therefore they wirk no longer properly.
  • Symptomatics would be an extremely slow work, sudden switching off by overheating, etc
Qué necesitas
Herramientas
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Dell Latitude 5310 - The Processor Fan failed to respond correctly, Performing an error diagnosis: paso 1, imagen 1 de 2 Dell Latitude 5310 - The Processor Fan failed to respond correctly, Performing an error diagnosis: paso 1, imagen 2 de 2
    • Turn off your computer
    • Turn on and constantly tapping F12
    • in the pre-boot menu choose "Diagnostics".
    • The Troubleshooting solved the specified error code 2000-0511.
  2. Dell Latitude 5310 - The Processor Fan failed to respond correctly, Remove the backcover: paso 2, imagen 1 de 3 Dell Latitude 5310 - The Processor Fan failed to respond correctly, Remove the backcover: paso 2, imagen 2 de 3 Dell Latitude 5310 - The Processor Fan failed to respond correctly, Remove the backcover: paso 2, imagen 3 de 3
    • place the laptop upside down on a soft, clean surface to avoid scratching
    • locate the screws (in this case 8)
    • use the screwdriver
    • 'Note: the screws are designe to stay attached in the back cover even after being unscrewed. This prevents loss.'
    • use the opening tool to open the back cover starting on the hinge areas. then move slowly around the edges
    • lift the open areas with your hand (lightly!) and slowly work using the tension along the edges.
  3. Dell Latitude 5310 - The Processor Fan failed to respond correctly, remove fan and clean: paso 3, imagen 1 de 3 Dell Latitude 5310 - The Processor Fan failed to respond correctly, remove fan and clean: paso 3, imagen 2 de 3 Dell Latitude 5310 - The Processor Fan failed to respond correctly, remove fan and clean: paso 3, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Remove the fan connector
    • Loosen 2x M2 screws remove the fan
    • Loosen 3x small slotted screws
    • Remove all possible dirt and dust (With the help of tweezers, compressed air, brush)
    • Try to rotate the Fan with your fingers slowly
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 22
Ultimos 30 días: 131
Todo El Tiempo: 1,735
