Saltar al contenido principal
Dell Latitude 3520 Speaker Replacement
Shawn Smith
Shawn Smith y 2 otros contribuidores
Última actualización: December 28, 2023
10 - 20 minutos
Moderado
Necesita más imágenes
Introducción
Ir al paso 1
Feel free to reference this comprehensive manual for step-by-step instructions on how to install brand-new speakers on your laptop. However, if your laptop's speakers produce distorted or subpar sound quality, and you find yourself puzzled about the root cause of this issue, this may be an excellent opportunity to explore the prospect of upgrading or replacing the speakers with higher-quality components.
Upgrading your laptop's speakers can significantly enhance your audio experience and breathe new life into your multimedia activities, providing clearer, more immersive sounds for movies, music, and video calls. By investing in superior speaker technology, you can unlock the full potential of your laptop's audio capabilities, delivering richer and more satisfying sound for your everyday computing needs.
So, whether you are embarking on a speaker installation journey or contemplating an upgrade, this manual is your trusted resource to achieve superior audio performance on your laptop.
Qué necesitas
Kits de reparación
Este kit contiene todas las piezas y herramientas necesarias para completar esta guía.
Partes
Herramientas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Ver más…
  1. Dell Latitude 3520 Speaker Replacement, Battery: paso 1, imagen 1 de 1
    • Slide the metal above the connector on the battery to unlock.
  2. Dell Latitude 3520 Speaker Replacement: paso 2, imagen 1 de 2 Dell Latitude 3520 Speaker Replacement: paso 2, imagen 2 de 2
    • Peel the adhesive tapes and the battery cable.
  3. Dell Latitude 3520 Speaker Replacement: paso 3, imagen 1 de 1
    • Disconnect the battery cable from the connector on the system board.
  4. Dell Latitude 3520 Speaker Replacement: paso 4, imagen 1 de 2 Dell Latitude 3520 Speaker Replacement: paso 4, imagen 2 de 2
    • Remove the three 2mm Phillip #0 screws that secure the battery in place.
  5. Dell Latitude 3520 Speaker Replacement: paso 5, imagen 1 de 1
    • Lift and remove the battery.
  6. Dell Latitude 3520 Speaker Replacement, Speaker: paso 6, imagen 1 de 2 Dell Latitude 3520 Speaker Replacement, Speaker: paso 6, imagen 2 de 2
    • Disconnect the speaker cable from the connector on the system board.
  7. Dell Latitude 3520 Speaker Replacement: paso 7, imagen 1 de 1
    • Unroute the speaker cable from the routing guides assembly.
  8. Dell Latitude 3520 Speaker Replacement: paso 8, imagen 1 de 1
    • Peel the adhesive tapes, lift them, and remove the speakers.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 26
Todo El Tiempo: 311
