Saltar al contenido principal
Dell Latitude 3520 RAMReplacement
Shawn Smith
Shawn Smith y 2 otros contribuidores
Última actualización: December 28, 2023
45 segundo - 1 minuto
Muy fácil
Introducción
Ir al paso 1
Utilize this manual to enhance and renew your laptop's RAM. Alternatively, have you experienced the frustration of your computer freezing at unpredictable intervals, making you feel as if you are on the brink of madness, especially when all you want to do is complete your work? This guide is at your disposal to assist you in upgrading your RAM and resolving these performance issues.
  1. Dell Latitude 3520 RAMReplacement, Remove MicroSD-card: paso 1, imagen 1 de 1
    • Push the microSD-card to eject it from the slot.
    • Remove the microSD-card from the computer.
  2. Dell Latitude 3520 RAMReplacement, Bottom Case: paso 2, imagen 1 de 3 Dell Latitude 3520 RAMReplacement, Bottom Case: paso 2, imagen 2 de 3 Dell Latitude 3520 RAMReplacement, Bottom Case: paso 2, imagen 3 de 3
    • Loosen the nine screws 2mm Phillips #0 that secure the base cover to the assembly.
    • Using a plastic scribe, pry open the base cover starting from the recesses located in the indents near the hinges at the top edge of the base cover.
    • Carefully lift and remove the base cover.
  3. Dell Latitude 3520 RAMReplacement, RAM: paso 3, imagen 1 de 2 Dell Latitude 3520 RAMReplacement, RAM: paso 3, imagen 2 de 2
    • Lift the clips to find the memory module slot.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 37
Todo El Tiempo: 266
