Saltar al contenido principal
Dell Latitude 3380 Touchpad Replacement
Cristofer
Cristofer y 2 otros contribuidores
Última actualización: December 21, 2021
30 minuto
Moderado
Introducción
Ir al paso 1
If the touchpad on your Dell Latitude 3380 does not respond quickly or is lagging, it might be time to replace it.
Before starting the replacement, make sure to power down the laptop completely and drain the battery by pressing the power button a few times. Also, make sure to have the touchpad replacement and tools.
Qué necesitas
Partes
Herramientas
  • Phillips #0 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Ver más…
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Dell Latitude 3380 Touchpad Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Latitude 3380 Touchpad Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Touchpad Replacement: paso 2, imagen 1 de 2 Dell Latitude 3380 Touchpad Replacement: paso 2, imagen 2 de 2
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Touchpad Replacement, Battery: paso 3, imagen 1 de 3 Dell Latitude 3380 Touchpad Replacement, Battery: paso 3, imagen 2 de 3 Dell Latitude 3380 Touchpad Replacement, Battery: paso 3, imagen 3 de 3
    • Remove the three 3 mm screws using a Phillips #0 screwdriver
    • Disconnect the the cable connected to the battery using a spudger.
    • Lift up on the outer edges of the battery to remove it from the laptop.
  4. Dell Latitude 3380 Touchpad Replacement, Touchpad: paso 4, imagen 1 de 3 Dell Latitude 3380 Touchpad Replacement, Touchpad: paso 4, imagen 2 de 3 Dell Latitude 3380 Touchpad Replacement, Touchpad: paso 4, imagen 3 de 3
    • Unplug the touchpad cable using a spudger.
    • Remove the seven screws with a Phillips #0 screwdriver.
    • Remove the metal plate and place it to the side.
  5. Dell Latitude 3380 Touchpad Replacement: paso 5, imagen 1 de 2 Dell Latitude 3380 Touchpad Replacement: paso 5, imagen 2 de 2
    • Remove the three screws with the Phillips #0 screwdriver.
    • Remove the touchpad from the laptop.
Conclusión
Cristofer
Miembro Desde 09/02/21
169 Reputación
2 Guías creadas
Equipo
Gateway, Team 1-3, Pee Fall 2021 Miembro de Gateway, Team 1-3, Pee Fall 2021
GCC-PEE-F21S1G3
Miembros de 3
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 11
Todo El Tiempo: 348
