Saltar al contenido principal
Dell Latitude 3380 Front Camera Replacement
Charlie Tracey
Charlie Tracey y 4 otros contribuidores
Última actualización: May 7, 2024
15 minuto
Moderado
Introducción
Ir al paso 1
This guide will aid in the replacement of the Dell Latitude 3380 front camera.
The front camera performs as an accessory for many applications on the laptop, including video calls and meetings, recording presentations, and taking exams. There are many reasons why your camera might need replacing, including hardware failure from impacts, outdated software, and even malware. Make sure to check that your laptop is updated to the most current software. If the issue remains, then your issue is not outdated software, and in return requires this process of replacement.
Qué necesitas
Herramientas
Ver más…
  1. Dell Latitude 3380 Front Camera Replacement, Back Cover: paso 1, imagen 1 de 2 Dell Latitude 3380 Front Camera Replacement, Back Cover: paso 1, imagen 2 de 2
    • Turn the laptop over so that the back is facing up.
    • Remove the nine 3 mm screws with a Phillips #0 screwdriver.
  2. Dell Latitude 3380 Front Camera Replacement: paso 2, imagen 1 de 2 Dell Latitude 3380 Front Camera Replacement: paso 2, imagen 2 de 2
    • Use an opening tool to pry the back cover away from the laptop.
  3. Dell Latitude 3380 Front Camera Replacement, Front Camera: paso 3, imagen 1 de 2 Dell Latitude 3380 Front Camera Replacement, Front Camera: paso 3, imagen 2 de 2
    • Disconnect the cable strip.
  4. Dell Latitude 3380 Front Camera Replacement: paso 4, imagen 1 de 1
    • Detach the power cable connecting the display to the motherboard.
  5. Dell Latitude 3380 Front Camera Replacement: paso 5, imagen 1 de 1
    • Remove the four screws holding the display in place using a Phillips #0 screwdriver.
  6. Dell Latitude 3380 Front Camera Replacement: paso 6, imagen 1 de 2 Dell Latitude 3380 Front Camera Replacement: paso 6, imagen 2 de 2
    • Using your fingers (or an opening tool if necessary), gently pry off the bottom cover on the display.
  7. Dell Latitude 3380 Front Camera Replacement: paso 7, imagen 1 de 2 Dell Latitude 3380 Front Camera Replacement: paso 7, imagen 2 de 2
    • Remove the screw caps, then the screws using a Phillips #0 screwdriver.
    • Remove the plastic outer covering using an opening tool.
  8. Dell Latitude 3380 Front Camera Replacement: paso 8, imagen 1 de 3 Dell Latitude 3380 Front Camera Replacement: paso 8, imagen 2 de 3 Dell Latitude 3380 Front Camera Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Remove the front camera by gently pulling it out with a pair of tweezers.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 84
