Saltar al contenido principal
Dell Latitude 3190 Battery Replacement
Daniel Tzunum
Daniel Tzunum y 7 otros contribuidores
Última actualización: February 11, 2025
15 - 30 minutos
Moderado
Introducción
Ir al paso 1
If your Dell Latitude 3190 laptop is losing power after a short amount of time after being unplugged, use this guide to replace the battery of the laptop.
The battery of a laptop allows the user to store power in the laptop for a certain amount of time while not having to be connected to an external power source such as an outlet in order for the laptop to work.
The laptop’s battery needs to be replaced when the battery is not powering the laptop very long before needing to be plugged in.
Before beginning this guide, be sure to power off your device and unplug it from the charging cable.
Qué necesitas
Partes
Herramientas
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
Ver más…
  1. Dell Latitude 3190 Battery Replacement, Base Cover: paso 1, imagen 1 de 2 Dell Latitude 3190 Battery Replacement, Base Cover: paso 1, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the seven 7 mm screws securing the back case.
  2. Dell Latitude 3190 Battery Replacement: paso 2, imagen 1 de 3 Dell Latitude 3190 Battery Replacement: paso 2, imagen 2 de 3 Dell Latitude 3190 Battery Replacement: paso 2, imagen 3 de 3
    • Using a plastic opening tool carefully separate the plastic base cover from the rest of the laptop.
    • Lift the bottom cover from the laptop.
  3. Dell Latitude 3190 Battery Replacement, Battery: paso 3, imagen 1 de 1
    • Locate the battery.
  4. Dell Latitude 3190 Battery Replacement: paso 4, imagen 1 de 3 Dell Latitude 3190 Battery Replacement: paso 4, imagen 2 de 3 Dell Latitude 3190 Battery Replacement: paso 4, imagen 3 de 3
    • Disconnect the battery cable located on the top of the battery.
    • Use the spudger and disconnect the battery cable.
    • Pull the cable out of the way.
  5. Dell Latitude 3190 Battery Replacement: paso 5, imagen 1 de 3 Dell Latitude 3190 Battery Replacement: paso 5, imagen 2 de 3 Dell Latitude 3190 Battery Replacement: paso 5, imagen 3 de 3
    • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the battery.
  6. Dell Latitude 3190 Battery Replacement: paso 6, imagen 1 de 3 Dell Latitude 3190 Battery Replacement: paso 6, imagen 2 de 3 Dell Latitude 3190 Battery Replacement: paso 6, imagen 3 de 3
    • Pull the black battery tap upwards to remove the battery.
    • The battery adhesive is strong, do not be afraid to use force. You may need to use the spudger or opening tool as a wedge.
Conclusión
Una persona más ha completado esta guía.
Daniel Tzunum
Miembro Desde 09/01/21
235 Reputación
2 Guías creadas
Equipo
Gateway, Team 1-5, Saknee Fall 2021 Miembro de Gateway, Team 1-5, Saknee Fall 2021
GCC-SAKNEE-F21S1G5
3 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 20
Ultimos 30 días: 56
Todo El Tiempo: 2,108
