Saltar al contenido principal
Dell Inspiron 3520 Keyboard Replacement
Ian
Ian y 3 otros contribuidores
Última actualización: August 9, 2019
5 minuto
Fácil
Introducción
Ir al paso 1
The Dell Inspiron 3520 has a basic keyboard that is easily accessible from the open surface of the notebook. The 3520 model does not have a keyboard backlight. This makes the keyboard much simpler to remove. Keep in mind that this will require some force on the repairers part.
Qué necesitas
Herramientas
  • Spudger
    Spudger
  1. Dell Inspiron 3520 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 3520 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Keyboard Replacement: paso 2, imagen 1 de 3 Dell Inspiron 3520 Keyboard Replacement: paso 2, imagen 2 de 3 Dell Inspiron 3520 Keyboard Replacement: paso 2, imagen 3 de 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 2 Dell Inspiron 3520 Keyboard Replacement, Keyboard: paso 3, imagen 2 de 2
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Keyboard Replacement: paso 4, imagen 1 de 1
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Keyboard Replacement: paso 5, imagen 1 de 2 Dell Inspiron 3520 Keyboard Replacement: paso 5, imagen 2 de 2
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
Conclusión
7 personas más completaron esta guía.
Ian
Miembro Desde 01/30/15
1,557 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 16-2, Watkins Winter 2015 Miembro de USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Miembros
5 Guías creadas
Un comentario
Hi, any ideas why a NEW keyboard still wouldn't work after installing it? The ribbon was connected properly, it’s the right keyboard, and I made sure the driver was updated. Any help would be greatly appreciated. Started a new job and my keyboard went to $@$* in the first week. Can’t really afford to buy a new laptop this weekend. It works with an external USB keyboard so it’s probably not a software issue… I think?
Alittle advice would be greatly appreciated. Thanks!
Stumpedu - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 44
Todo El Tiempo: 6,385
