Saltar al contenido principal
Dell Inspiron 3520 Battery Replacement
Ian
Ian y otro contribuidor
Última actualización: June 11, 2015
1 minuto
Muy fácil
Introducción
Ir al paso 1
The Dell Inspiron 3520 has a lithium-ion battery that is easily accessible from the underside of the notebook. As a reminder, when disposing of the old battery, place it in an e-waste container.
  1. Dell Inspiron 3520 Battery Replacement, Battery: paso 1, imagen 1 de 2 Dell Inspiron 3520 Battery Replacement, Battery: paso 1, imagen 2 de 2
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Battery Replacement: paso 2, imagen 1 de 3 Dell Inspiron 3520 Battery Replacement: paso 2, imagen 2 de 3 Dell Inspiron 3520 Battery Replacement: paso 2, imagen 3 de 3
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
Conclusión
Ian
Miembro Desde 01/30/15
1,557 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 16-2, Watkins Winter 2015 Miembro de USF Tampa, Team 16-2, Watkins Winter 2015
USFT-WATKINS-W15S16G2
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 6
Ultimos 7 días: 22
Ultimos 30 días: 49
Todo El Tiempo: 3,233
