Saltar al contenido principal
Dell Inspiron 17-3721 Optical Drive Replacement
Kevin Prairie
Kevin Prairie y 2 otros contribuidores
Última actualización: May 9, 2018
10 - 15 minutos
Moderado
Introducción
Ir al paso 1
A broken optical drive will prohibit users from reading or loading anything from a disk onto their laptop. This guide will show the steps to replace the optical drive on this device.
Qué necesitas
Herramientas
Ver más…
  1. Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: paso 1, imagen 1 de 2 Dell Inspiron 17-3721 Optical Drive Replacement, Keyboard: paso 1, imagen 2 de 2
    • Use a plastic opening tool or a metal spudger to pry out the tabs on top of the keyboard.
    • After prying the tabs up, carefully pull the keyboard out of the laptop.
    • Use caution when prying the tabs up or lifting the keyboard up, as the plastic material and the strip on the keyboard can easily break.
  2. Dell Inspiron 17-3721 Optical Drive Replacement: paso 2, imagen 1 de 2 Dell Inspiron 17-3721 Optical Drive Replacement: paso 2, imagen 2 de 2
    • Once the keyboard is lifted, locate the release tab.
    • Using a plastic opening tool or your finger, lift the tab so that it opens .
    • Once the tab is open, the strip on the keyboard can be removed.
  3. Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: paso 3, imagen 1 de 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: paso 3, imagen 2 de 3 Dell Inspiron 17-3721 Optical Drive Replacement, Optical Drive: paso 3, imagen 3 de 3
    • Remove the four 6 mm PH1 Philips head screws under the keyboard.
    • Carefully pop off the cover using the plastic opening tools and your hands.
  4. Dell Inspiron 17-3721 Optical Drive Replacement: paso 4, imagen 1 de 3 Dell Inspiron 17-3721 Optical Drive Replacement: paso 4, imagen 2 de 3 Dell Inspiron 17-3721 Optical Drive Replacement: paso 4, imagen 3 de 3
    • Remove the 4 mm PH1 Philips head screw holding down the optical drive.
    • Use your hand to slide the drive out of the device.
Conclusión
Una persona más ha completado esta guía.
Kevin Prairie
Miembro Desde 03/20/18
445 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 25
Todo El Tiempo: 363
