Saltar al contenido principal
Dell Inspiron 17 Laptop Battery Replacement
Anmol Desai
Anmol Desai y otro contribuidor
Última actualización: October 14, 2024
Sin estimación
Moderado
Necesita mejores imágenes
Introducción
Ir al paso 1
Welcome to our guide on how to replace your Dell laptop's battery. We understand that not everyone is a tech expert, and that's perfectly fine. This guide is here to walk you through the process of replacing your laptop's battery in a clear and easy-to-follow manner. Tools and Parts are also mentioned. This is required incase if your battery is not performing to the best ability.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Dell Inspiron 17 Laptop Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Before starting, make sure the laptop is powered off and disconnected from any power sources.
  2. Dell Inspiron 17 Laptop Battery Replacement: paso 2, imagen 1 de 1
    • Remove the Screws of the Laptop with help screwdriver.
    • There are 6 screws to remove. Make Sure to open the back of the laptop delicately.
  3. Dell Inspiron 17 Laptop Battery Replacement: paso 3, imagen 1 de 1
    • Carefully disconnect the old battery from the motherboard.
    • Gently remove the old battery from its housing by removing plug of battery.
  4. Dell Inspiron 17 Laptop Battery Replacement: paso 4, imagen 1 de 1
    • Insert the new battery into the housing.
    • Connect the new battery to the motherboard.
    • Securely reattach the battery back cover.
  5. Dell Inspiron 17 Laptop Battery Replacement: paso 5, imagen 1 de 1
    • Plug in the laptop and charge it to Full Capacity.
    • Power on the laptop and make sure it works with the new battery.
Conclusión
6 personas más completaron esta guía.
Anmol Desai
Miembro Desde 09/14/23
286 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 42
Ultimos 7 días: 232
Ultimos 30 días: 351
Todo El Tiempo: 3,401
