Saltar al contenido principal
Dell Inspiron 1525 Central Control Cover Replacement
Miroslav Djuric
Miroslav Djuric y 2 otros contribuidores
Última actualización: November 13, 2015
10 minuto
Moderado
Introducción
Ir al paso 1
Use this guide to help you replace the Central Control Cover on a Dell Inspiron 1525.
Qué necesitas
Herramientas
  1. Dell Inspiron 1525 Central Control Cover Replacement, Battery: paso 1, imagen 1 de 1
    • Locate the battery release switch on the bottom of the laptop.
  2. Dell Inspiron 1525 Central Control Cover Replacement: paso 2, imagen 1 de 2 Dell Inspiron 1525 Central Control Cover Replacement: paso 2, imagen 2 de 2
    • Slide the battery release switch away from the lock symbol until you hear the battery click.
    • Slide the battery towards the back of the laptop until it comes free.
  3. Dell Inspiron 1525 Central Control Cover Replacement, Central Control Cover: paso 3, imagen 1 de 1
    • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
  4. Dell Inspiron 1525 Central Control Cover Replacement: paso 4, imagen 1 de 3 Dell Inspiron 1525 Central Control Cover Replacement: paso 4, imagen 2 de 3 Dell Inspiron 1525 Central Control Cover Replacement: paso 4, imagen 3 de 3
    • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
    • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
  5. Dell Inspiron 1525 Central Control Cover Replacement: paso 5, imagen 1 de 3 Dell Inspiron 1525 Central Control Cover Replacement: paso 5, imagen 2 de 3 Dell Inspiron 1525 Central Control Cover Replacement: paso 5, imagen 3 de 3
    • Peel back the silver tape securing the ribbon cable to the cover.
    • Pull the small brown latch on the ribbon cable connector out.
    • Disconnect the ribbon cable to completely free the central control cover.
Conclusión
4 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 22
Todo El Tiempo: 3,648
