Dell Inspiron 15-5558 Screen Replacement
Introducción
Ir al paso 1If your device screen breaks, you might need to replace it. The screen is the part of the device when images are displayed. This guide shows you how to replace a broken or faulty screen
Qué necesitas
Herramientas
Open device so it is at least opened at a 90 degree angle.
Wedge a spudger between the screen and the plastic frame.
Push in the spudger and push down to pop the frame from the pins.
Repeat around the whole frame.
7 personas más completaron esta guía.
3 comentarios
How many pins is the screen connector? 30? 40?
Very useful guide. Works with Dell Inspiron 15 5559. Screen replacement is a lot easier than replacing the whole screen assembly.
