Saltar al contenido principal
Dell Inspiron 15-5548 RAM Replacement
Qué necesitas
  1. Dell Inspiron 15-5548 RAM Replacement, RAM: paso 1, imagen 1 de 3 Dell Inspiron 15-5548 RAM Replacement, RAM: paso 1, imagen 2 de 3 Dell Inspiron 15-5548 RAM Replacement, RAM: paso 1, imagen 3 de 3
    • Unplug and power off the laptop.
    • Turn the laptop over so that the grill for the fans is at the top. Locate the two screws above the grill.
    • Remove the screws with a Phillips 00 Screwdriver.
  2. Dell Inspiron 15-5548 RAM Replacement: paso 2, imagen 1 de 2 Dell Inspiron 15-5548 RAM Replacement: paso 2, imagen 2 de 2
    • Use the iFixit opening tool to lift up on the casing and remove it from the laptop.
  3. Dell Inspiron 15-5548 RAM Replacement: paso 3, imagen 1 de 3 Dell Inspiron 15-5548 RAM Replacement: paso 3, imagen 2 de 3 Dell Inspiron 15-5548 RAM Replacement: paso 3, imagen 3 de 3
    • Locate the RAM sticks on the left side of the device.
    • On both ends of the RAM stick, pull the metal tabs away from each other.
    • The RAM stick will pop up. Gently pull the RAM stick out.
Conclusión
Jacob Cotton
Miembro Desde 09/20/17
101 Reputación
1 Guía escrita
Un comentario
Hi Mr Cotton. Greetings. I have a Dell Inspiron 5548. Can I replace the present 8GB ram with 32GB in any type of DDR4 laptop ram?
Please respond to lucien395@gmail.com
Thank you
George Livingstone - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 632
