Saltar al contenido principal
Dell Inspiron 15-3531 Keyboard Replacement
Kody Dahlke
Kody Dahlke y 6 otros contribuidores
Última actualización: June 19, 2024
5 - 10 minutos
Fácil
Introducción
Ir al paso 1
As laptop keyboards age, they may lose keys or stop responding to any interaction and may need to be replaced. Make sure the keyboard is not near any hazardous materials that could destroy the keyboard during the removal process.
Qué necesitas
Herramientas
  1. Dell Inspiron 15-3531 Keyboard Replacement, Battery: paso 1, imagen 1 de 3 Dell Inspiron 15-3531 Keyboard Replacement, Battery: paso 1, imagen 2 de 3 Dell Inspiron 15-3531 Keyboard Replacement, Battery: paso 1, imagen 3 de 3
    • Remove the battery to avoid electrical discharge while working with this system.
    • Flip the laptop over.
    • Slide the latches toward the edges to unlock the battery.
    • Lift the battery out of the laptop.
  2. Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: paso 2, imagen 1 de 3 Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: paso 2, imagen 2 de 3 Dell Inspiron 15-3531 Keyboard Replacement, Keyboard: paso 2, imagen 3 de 3
    • Depress (push in, not down) the five tabs at the top of the keyboard and the two on each side of the keyboard with a flat head screwdriver.
    • Pry the keyboard from the laptop using the spudger.
    • Be careful when lifting it out because there is a cable connecting the keyboard to the laptop.
  3. Dell Inspiron 15-3531 Keyboard Replacement: paso 3, imagen 1 de 3 Dell Inspiron 15-3531 Keyboard Replacement: paso 3, imagen 2 de 3 Dell Inspiron 15-3531 Keyboard Replacement: paso 3, imagen 3 de 3
    • Lift the latch holding down the cable using a flat head screwdriver.
    • Slide the cable out.
    • This will free the keyboard from the laptop.
Conclusión
2 personas más completaron esta guía.
Kody Dahlke
Miembro Desde 02/15/18
742 Reputación
5 Guías creadas
Equipo
USF Tampa, Team S1-G5, Leahy Spring 2018 Miembro de USF Tampa, Team S1-G5, Leahy Spring 2018
USFT-LEAHY-S18S1G5
5 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 22
Todo El Tiempo: 628
