Saltar al contenido principal
Dell Inspiron 15 5584 CPU Thermal Paste Replacement
Sam Vorn
Sam Vorn y 3 otros contribuidores
Última actualización: March 29, 2024
10 - 15 minutos
Moderado
Introducción
Ir al paso 1
Use this guide to replace the thermal paste on your Dell Inspiron 15 5584's CPU.
The processor, also known as the CPU, provides instructions and processing power for your device to function. It allows your computer to run applications and programs, as well as create the interface you interact with. Thermal paste, the silver-grey substance found above the CPU, allows for the cooling of the processor by dissipating heat. Without thermal paste, or with old thermal paste, the device will eventually overheat, and become nonfunctional.
Before using this guide, make sure to wear gloves and use the proper cleaning tools. It is important to note that, while thermal paste is skin safe, it is extremely toxic if consumed, rubbed into the eyes, or any open orifice. If consumed, contact your closest poison control center.
You can find detailed instructions here for reapplying thermal paste.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Dell Inspiron 15 5584 CPU Thermal Paste Replacement, Bottom Cover: paso 1, imagen 1 de 1
    • Make sure to turn off and unplug your laptop before starting.
    • Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
  2. Dell Inspiron 15 5584 CPU Thermal Paste Replacement: paso 2, imagen 1 de 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: paso 2, imagen 2 de 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: paso 2, imagen 3 de 3
    • Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
    • Loosen the two captive back corner screws using a Phillips #0 screwdriver.
    • The two corner screws are not removable. A clicking sounds indicates that the screw is fully loosened.
  3. Dell Inspiron 15 5584 CPU Thermal Paste Replacement: paso 3, imagen 1 de 2 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: paso 3, imagen 2 de 2
    • Slide an iFixit opening tool underneath the right side USB port and the keyboard.
    • Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
    • Be careful not to force open the plate or push too much off without loosening the other sides. This can cause the bottom cover to crack.
  4. Dell Inspiron 15 5584 CPU Thermal Paste Replacement: paso 4, imagen 1 de 2 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: paso 4, imagen 2 de 2
    • Gently pry off the bottom cover from the laptop.
    • Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
  5. Dell Inspiron 15 5584 CPU Thermal Paste Replacement, Battery: paso 5, imagen 1 de 2 Dell Inspiron 15 5584 CPU Thermal Paste Replacement, Battery: paso 5, imagen 2 de 2
    • Remove the four 3.5 mm screws holding the battery down with a JIS #0 screwdriver.
  6. Dell Inspiron 15 5584 CPU Thermal Paste Replacement: paso 6, imagen 1 de 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: paso 6, imagen 2 de 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement: paso 6, imagen 3 de 3
    • Detach the motherboard connector tab from the top left of the battery.
    • Remove the battery from the device.
    • Be sure to carefully wiggle the connector out from the battery socket. Ripping it out too forcefully could damage the socket.
  7. Dell Inspiron 15 5584 CPU Thermal Paste Replacement, CPU Thermal Paste: paso 7, imagen 1 de 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement, CPU Thermal Paste: paso 7, imagen 2 de 3 Dell Inspiron 15 5584 CPU Thermal Paste Replacement, CPU Thermal Paste: paso 7, imagen 3 de 3
    • Loosen the four captive 3.5 mm screws securing the heat sink to the motherboard using a Phillips #0 screwdriver.
    • Remove the CPU plate cover from the motherboard and safely place it off to the side.
  8. Dell Inspiron 15 5584 CPU Thermal Paste Replacement: paso 8, imagen 1 de 1
    • Place a small amount of rubbing alcohol on either a paper towel or cotton swab.
    • Use the paper towel or cotton swab to completely remove the thermal paste from the CPU.
    • Leave it to dry for around an hour before applying the new thermal paste. You can find thermal paste application instructions here.
Conclusión
Una persona más ha completado esta guía.
Sam Vorn
Miembro Desde 03/29/22
977 Reputación
9 Guías creadas
Equipo
UMass Dartmouth, Team 1-1, Mellen Spring 2022 Miembro de UMass Dartmouth, Team 1-1, Mellen Spring 2022
UMASSD-MELLEN-S22S1G1
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 21
Ultimos 30 días: 36
Todo El Tiempo: 887
