Dell Inspiron 11-3152 USB Port Replacement
Introducción
Ir al paso 1This guide will show you how to replace the USB Ports on your Dell Inspiron.
Qué necesitas
Herramientas
After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
Remove the two white power connectors on the bottom right of the motherboard by gently pulling on the tabs backward.
Una persona más ha completado esta guía.
