Saltar al contenido principal
Dell Inspiron 11-3152 Battery Replacement
Matthew Duncan
Matthew Duncan y 4 otros contribuidores
Última actualización: May 18, 2017
10 minuto
Moderado
Introducción
Ir al paso 1
In this guide, you will be replacing the battery to your Dell Inspiron. When finished, you should understand how to dissemble the back panel and remove the battery.
Qué necesitas
Herramientas
Ver más…
  1. Dell Inspiron 11-3152 Battery Replacement, Back Panel: paso 1, imagen 1 de 2 Dell Inspiron 11-3152 Battery Replacement, Back Panel: paso 1, imagen 2 de 2
    • Flip the computer over.
  2. Dell Inspiron 11-3152 Battery Replacement: paso 2, imagen 1 de 2 Dell Inspiron 11-3152 Battery Replacement: paso 2, imagen 2 de 2
    • Remove all nine 5mm Phillips head screws from the back cover using #0 Phillips head.
  3. Dell Inspiron 11-3152 Battery Replacement: paso 3, imagen 1 de 1
    • Gently use a spudger to pull the cover away from the rest of the laptop. The cover will come off after you use the tool on two or three sides.
  4. Dell Inspiron 11-3152 Battery Replacement, Battery: paso 4, imagen 1 de 1
    • Make sure that the power is off.
    • After taking off the back panel, you will see the battery located at the bottom of the computer system. It's black and is clearly labeled "dell battery".
  5. Dell Inspiron 11-3152 Battery Replacement: paso 5, imagen 1 de 2 Dell Inspiron 11-3152 Battery Replacement: paso 5, imagen 2 de 2
    • Locate the battery at the bottom of the computer and remove the four 3mm screws with a Phillips #0 head that hold the battery down.
  6. Dell Inspiron 11-3152 Battery Replacement: paso 6, imagen 1 de 1
    • Remove the Solid State Drive wire from the battery clip by detaching the wire.
    • This can be done by gently pulling the connector away from the battery clip.
  7. Dell Inspiron 11-3152 Battery Replacement: paso 7, imagen 1 de 1
    • Remove the battery from the computer system by gently lifting it from the side.
Conclusión
Una persona más ha completado esta guía.
Matthew Duncan
Miembro Desde 03/10/16
481 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 17
Todo El Tiempo: 815
