Saltar al contenido principal
Dell Inspiron 11-3147 Wireless Card Replacement
William Brum
William Brum y 3 otros contribuidores
Última actualización: May 19, 2016
15 minuto
Moderado
Introducción
Ir al paso 1
If your internet connection has proven consistently faulty and internet connect drops frequently despite a working connection , you may need to replace your wireless card. Ensure your laptop is both unplugged and turned off before working on it in any way. Use plastic tools only, as accidents with metal tools can cause fires.
Qué necesitas
Partes
Herramientas
Ver más…
  1. Dell Inspiron 11-3147 Wireless Card Replacement, Wireless Card: paso 1, imagen 1 de 2 Dell Inspiron 11-3147 Wireless Card Replacement, Wireless Card: paso 1, imagen 2 de 2
    • Using a plastic Philips Head #1 Screw Driver, remove the nine 7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic spudgercan be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 Wireless Card Replacement: paso 2, imagen 1 de 1
    • Remove the single 3mm screw holding down the hardware using a plastic Philips Head #0 Screw Driver.
  3. Dell Inspiron 11-3147 Wireless Card Replacement: paso 3, imagen 1 de 1
    • Detach the wires connected to the wireless card.
  4. Dell Inspiron 11-3147 Wireless Card Replacement: paso 4, imagen 1 de 1
    • Ensure both wires are detached from the piece.
  5. Dell Inspiron 11-3147 Wireless Card Replacement: paso 5, imagen 1 de 1
    • Lift the wireless card upwards and remove.
Conclusión
2 personas más completaron esta guía.
William Brum
Miembro Desde 03/04/16
755 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 11
Ultimos 30 días: 30
Todo El Tiempo: 1,382
