Saltar al contenido principal
Dell Inspiron 11-3147 RAM Replacement
William Brum
William Brum y 3 otros contribuidores
Última actualización: August 8, 2019
20 minuto
Moderado
Introducción
Ir al paso 1
This guide provides the necessary steps involved with Replacing broken or failing RAM. The only tool needed is a #1 Philips head screw driver for the removal of the back case. This is a quick and simple process as long as the guides are followed exactly as explained.
Qué necesitas
Herramientas
  1. Dell Inspiron 11-3147 RAM Replacement, RAM: paso 1, imagen 1 de 2 Dell Inspiron 11-3147 RAM Replacement, RAM: paso 1, imagen 2 de 2
    • Using a Philips Head #1 Screw Driver remove the nine .7mm screws holding the back cover in place.
    • The cover is held on with small plastic tabs. Starting from the back of the machine use your hands to gently prey the back cover from the machine and release these tabs. While a tool is not necessary a plastic plunger can be used to lift the first few tabs.
  2. Dell Inspiron 11-3147 RAM Replacement: paso 2, imagen 1 de 2 Dell Inspiron 11-3147 RAM Replacement: paso 2, imagen 2 de 2
    • Place finger nails on both of the little metal tabs that are located on shorter sides of the Ram board.
    • Pull tabs outward and away from the Ram card. This will detach the card from the computer and allow removal.
  3. Dell Inspiron 11-3147 RAM Replacement: paso 3, imagen 1 de 1
    • Carefully remove the RAM to ensure no other components get damaged.
    • Replace with a new RAM card the exact way it came out, with the the shiny metallic part of the card placed inside black insert as shown in the picture.
Conclusión
4 personas más completaron esta guía.
William Brum
Miembro Desde 03/04/16
755 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 21
Todo El Tiempo: 1,343
