Saltar al contenido principal
Dell Dimension 4600 Optical Drive Replacement
Eugene
Eugene y 9 otros contribuidores
Última actualización: December 8, 2022
10 - 15 minutos
Moderado
Necesita mejores imágenes
Introducción
Ir al paso 1
Use this guide to replace the optical drive in your Dell Dimension 4600.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Dell Dimension 4600 Optical Drive Replacement, Side Panel: paso 1, imagen 1 de 1
    • Locate the case cover latch on the back of the computer.
  2. Dell Dimension 4600 Optical Drive Replacement: paso 2, imagen 1 de 1
    • Using your index finger, slide and hold the cover latch down.
    • While holding the latch down, place your other hand flat on the side of the case and firmly shift the side panel to the left until it disengages.
  3. Dell Dimension 4600 Optical Drive Replacement: paso 3, imagen 1 de 1
    • Grab the edge of the panel and slide it away from the case until it is removed.
  4. Dell Dimension 4600 Optical Drive Replacement, Optical Drive: paso 4, imagen 1 de 1
    • Locate the Optical Drive by finding it externally on the case.
  5. Dell Dimension 4600 Optical Drive Replacement: paso 5, imagen 1 de 2 Dell Dimension 4600 Optical Drive Replacement: paso 5, imagen 2 de 2
    • Press and hold the three levers located behind the front panel.
    • While holding the levers down, swing open the front panel.
  6. Dell Dimension 4600 Optical Drive Replacement: paso 6, imagen 1 de 1
    • Swing the front of the case open until it separates from the main case.
  7. Dell Dimension 4600 Optical Drive Replacement: paso 7, imagen 1 de 3 Dell Dimension 4600 Optical Drive Replacement: paso 7, imagen 2 de 3 Dell Dimension 4600 Optical Drive Replacement: paso 7, imagen 3 de 3
    • Lay the computer flat on it's side so that you are looking down on all of the components.
    • Locate the Drive 1 cable and where it is connected to the motherboard.
  8. Dell Dimension 4600 Optical Drive Replacement: paso 8, imagen 1 de 1
    • Grasp the end of the Drive 1 cable connected to the motherboard and firmly pull upwards until it is removed.
  9. Dell Dimension 4600 Optical Drive Replacement: paso 9, imagen 1 de 2 Dell Dimension 4600 Optical Drive Replacement: paso 9, imagen 2 de 2
    • Locate the end of the Drive 1 cable connected to the optical drive.
    • Grasp the cable and pull firmly to disconnect it from the optical drive.
  10. Dell Dimension 4600 Optical Drive Replacement: paso 10, imagen 1 de 2 Dell Dimension 4600 Optical Drive Replacement: paso 10, imagen 2 de 2
    • Locate the screw on the optical drive.
    • Remove the 7.7 mm screw by using a Phillips #2 screw-driver.
  11. Dell Dimension 4600 Optical Drive Replacement: paso 11, imagen 1 de 1
    • Remove the optical drive by sliding it out of the front of the case.
Conclusión
13 personas más completaron esta guía.
Eugene
Miembro Desde 10/12/11
216 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 6-10, Regan Fall 2011 Miembro de Cal Poly, Team 6-10, Regan Fall 2011
CPSU-REGAN-F11S6G10
4 Miembros
11 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 25
Todo El Tiempo: 6,744
