Saltar al contenido principal
Dell Chromebook 3100 2-in-1 Webcam Replacement
ot moya
ot moya y 3 otros contribuidores
Última actualización: December 27, 2023
30 minuto - 1 hora
Moderado
Introducción
Ir al paso 1
This guide will tell you step-by-step how to replace the webcam in the Dell Chromebook 3100 2-in-1.
Before beginning, make sure to power off your phone completely and disconnect from any external power source.
Qué necesitas
Herramientas
  1. Dell Chromebook 3100 2-in-1 Webcam Replacement, Webcam: paso 1, imagen 1 de 1
    • Using a Phillips screw driver (PH1) remove the 9 (M2.5x4) screws holding the back cover
  2. Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 2, imagen 1 de 1
    • Using a jimmy and remove the plastic covering to reveal internal hardware.
  3. Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 3, imagen 1 de 1
    • Unplug the battery from the motherboard by pulling gently.
  4. Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 4, imagen 1 de 1
    • Remove the single screw (M2x3).
    • Remove the bracket over the Wi-Fi and camera plugs.
  5. Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 5, imagen 1 de 1
    • Unplug the now revealed camera and Wi-Fi antennas by gently pulling.
  6. Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 6, imagen 1 de 1
    • Remove the single screw (M2x4).
    • Remove the bracket over the display cable.
  7. Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 7, imagen 1 de 1
    • Lift the black tab and gently pull on the display cable to disconnect it.
  8. Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 8, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 8, imagen 2 de 2
    • Remove the 6 screws (M2.5x5) holding the hinges on both ends.
    • When both brackets are free, separte the screen from the computer screen from the bottom section.
  9. Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 9, imagen 1 de 1
    • Use a jimmy to pry between the 2 layers of the now disconnected display.
  10. Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 10, imagen 1 de 1
    • Unplug the webcam by gently pulling on the cable shown.
  11. Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 11, imagen 1 de 2 Dell Chromebook 3100 2-in-1 Webcam Replacement: paso 11, imagen 2 de 2
    • Use a jimmy to pry up the webcam, which is to then be removed.
Conclusión
ot moya
Miembro Desde 11/09/23
481 Reputación
3 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Fall 2023 Miembro de IUPUI, Team 3-2, Harley Fall 2023
IUPUI-HARLEY-F23S3G2
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 17
Ultimos 30 días: 32
Todo El Tiempo: 303
