Saltar al contenido principal
DJI Phantom 4 Advanced Remote Controller Motherboard Replacement
cade knott
cade knott y 6 otros contribuidores
Última actualización: August 12, 2021
10 - 15 minutos
Difícil
Fotos de acción
Introducción
Ir al paso 1
This guide will show you how to remove and replace the motherboard of the DJI Phantom 4 Advanced Remote Controller.
Before you begin:
  • Please make sure to completely power off the the controller prior to any replacements.
  • Please read the guide before any replacements in order to familiarize yourself with the process.
Qué necesitas
Partes
Herramientas
Ver más…
  1. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Back Panel: paso 1, imagen 1 de 1
    • Remove the four screws with a Torx T8 screwdriver to access the back con board.
  2. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: paso 2, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: paso 2, imagen 2 de 2
    • Remove three screws using a Phillips #00 screwdriver.
  3. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: paso 3, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: paso 3, imagen 2 de 2
    Herramienta utilizada en este paso:
    • With tweezers, gently remove the large con board tab.
    • Use your hands to remove the two small clips. Pull out from the socket, in a horizontal direction.
  4. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: paso 4, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: paso 4, imagen 2 de 2
    • Peel off the rubber grips to access the screw holes.
    • Make sure to save your grips and do not to get them stuck to anything, you are going to want to save the adhesive.
    • Remove the back board and set it aside.
  5. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: paso 5, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: paso 5, imagen 2 de 2
    • Pull apart the back plastic panel.
    • Recommended tool for this would be the metal spudger, but not required.
    • Once the back panel is off, you will have access to the motherboard.
  6. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: paso 6, imagen 1 de 3 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: paso 6, imagen 2 de 3 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement, Motherboard: paso 6, imagen 3 de 3
    • Disconnect ribbon tabs 1,2,5,8G, and 3.
    • Remove ribbon tab by pulling gently along motherboard. Do not pull straight out.
    • Then remove the plugs
  7. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: paso 7, imagen 1 de 2 DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: paso 7, imagen 2 de 2
    • With the Phillips #00 screwdriver, remove the two Phillips screws.
  8. DJI Phantom 4 Advanced Remote Controller Motherboard Replacement: paso 8, imagen 1 de 1
    • Double check to make sure all tabs, plugs and screws are removed or disconnected.
    • Gently lift motherboard out of the case.
Conclusión
2 personas más completaron esta guía.
2 comentarios
Do you know here can i buy a main board for phantom 4 advanced remote controller?
carl_darklife - Contestar
I would like to know too, can’t find one anywhere
Luke James -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 2,202
