Saltar al contenido principal
DJI Phantom 3 Standard Remote Controller Antenna Replacement
Makayla Williams
Makayla Williams y 3 otros contribuidores
Última actualización: January 3, 2025
5 - 10 minutos
Fácil
Introducción
Ir al paso 1
This guide will be used to open the DJI Phantom 3 Standard Remote Controller to access and replace the antenna. Antennas are a crucial controller component because they allow for communication between the controller and the drone. An antenna replacement can improve the connection between your controller and the drone. Some antennas provide a larger controller range compared to the stock antenna.
Qué necesitas
Herramientas
  1. DJI Phantom 3 Standard Remote Controller Antenna Replacement, Antenna: paso 1, imagen 1 de 2 DJI Phantom 3 Standard Remote Controller Antenna Replacement, Antenna: paso 1, imagen 2 de 2
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a JIS #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
  2. DJI Phantom 3 Standard Remote Controller Antenna Replacement: paso 2, imagen 1 de 2 DJI Phantom 3 Standard Remote Controller Antenna Replacement: paso 2, imagen 2 de 2
    • Use a spudger to pry the gray antenna wire from the glue.
    • There is a small metal piece latched in and should be removed from its place as well.
    • While a plastic spudger can be used, the attachment is secure. A metal spudger may produce better results.
  3. DJI Phantom 3 Standard Remote Controller Antenna Replacement: paso 3, imagen 1 de 1
    • Push the wire up to the antenna.
  4. DJI Phantom 3 Standard Remote Controller Antenna Replacement: paso 4, imagen 1 de 1
    • Squeeze and twist the outer antenna attachment to unlatch it from its place.
    • Remove the antenna.
Conclusión
Makayla Williams
Miembro Desde 09/04/24
209 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 19
Ultimos 30 días: 48
Todo El Tiempo: 94
