Saltar al contenido principal
Corsair HS80 Earpad Replacement
miaLau
miaLau y otro contribuidor
Última actualización: January 8, 2025
20 minuto
Fácil
Introducción
Ir al paso 1
With prolonged use and improper storage, the earpad cushions on a headset may detach from the earpad. These earpads have a unique shape, and buying replacement earpads may be expensive as they are only available on the Corsair website with $10 shipping. This guide will demonstrate how to fix the broken earpad.
Steps 4 to 7 uses strong adhesives that may result in skin irritation or bonded skin. Wear gloves or have a glue debonder ready.
Before beginning, set up the project in a well-ventilated area as adhesive fumes may irritate eyes and cause respiratory irritation.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Corsair HS80 Earpad Replacement, Earpad: paso 1, imagen 1 de 3 Corsair HS80 Earpad Replacement, Earpad: paso 1, imagen 2 de 3 Corsair HS80 Earpad Replacement, Earpad: paso 1, imagen 3 de 3
    • Remove the earpad from the headset by holding the earpad and twisting clockwise.
    • The earpad may be difficult to remove if doing so for the first time.
  2. Corsair HS80 Earpad Replacement: paso 2, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 2, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 2, imagen 3 de 3
    • Clean the area around the earpad speakers and cushion. A paper towel will suffice if only dust is being cleaned off.
  3. Corsair HS80 Earpad Replacement: paso 3, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 3, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 3, imagen 3 de 3
    • Take a pair of scissors and cut the old adhesive as close as possible to the fabric still adhered.
    • This will leave space on the cushion for new adhesive.
  4. Corsair HS80 Earpad Replacement: paso 4, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 4, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 4, imagen 3 de 3
    • Apply adhesive to the free edge of the earpad where the cushion had detached.
    • Wear gloves while working with adhesive. You may super glue your fingers together or your skin to the project. Have a glue debonder on hand if gloves are not available.
  5. Corsair HS80 Earpad Replacement: paso 5, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 5, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 5, imagen 3 de 3
    • Pull the fabric to the newly prepared earpad and hold it flush to the black lining of the earpad.
  6. Corsair HS80 Earpad Replacement: paso 6, imagen 1 de 2 Corsair HS80 Earpad Replacement: paso 6, imagen 2 de 2
    • Wrap masking or painter's tape to hold the fabric and earpad together.
  7. Corsair HS80 Earpad Replacement: paso 7, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 7, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 7, imagen 3 de 3
    • Insert a needle or sewing pin to hold the tape in place while the adhesive dries.
  8. Corsair HS80 Earpad Replacement: paso 8, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 8, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 8, imagen 3 de 3
    • Once dry, remove the pin and tape from the earpad.
  9. Corsair HS80 Earpad Replacement: paso 9, imagen 1 de 3 Corsair HS80 Earpad Replacement: paso 9, imagen 2 de 3 Corsair HS80 Earpad Replacement: paso 9, imagen 3 de 3
    • Reattach the earpad by lining the earpad in a clockwise direction and twist counter-clockwise to secure the earpad back into place.
Linea de Meta
miaLau
Miembro Desde 10/23/24
169 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 22
Todo El Tiempo: 61
