Saltar al contenido principal
Coolpix S01 Zoom Trigger Replacement
Qué necesitas
  1. Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: paso 1, imagen 1 de 3 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: paso 1, imagen 2 de 3 Coolpix S01 Zoom Trigger Replacement, Zoom Trigger: paso 1, imagen 3 de 3
    • Before starting, make sure the camera is powered off.
    • Take the Hex and PH000 bit to remove a 2mm screw from the left side of the camera.
    • Next, remove the 2mm screw from the right side.
    • Lastly, remove the 3mm screw from the bottom of the camera.
  2. Coolpix S01 Zoom Trigger Replacement: paso 2, imagen 1 de 3 Coolpix S01 Zoom Trigger Replacement: paso 2, imagen 2 de 3 Coolpix S01 Zoom Trigger Replacement: paso 2, imagen 3 de 3
    • Once the two 2mm screws and the 3 mm screw have been removed, use the smallest plastic opening tool and pull up on the sides to reveal the inside of the camera.
    • Be sure to remove the battery before continuing your repair.
  3. Coolpix S01 Zoom Trigger Replacement: paso 3, imagen 1 de 2 Coolpix S01 Zoom Trigger Replacement: paso 3, imagen 2 de 2
    • After the battery is out, remove the gray button bar from the top of the camera with the smallest opening tool.
    • With the gray bar detached from the camera, turn it upside down. With the Hex and the J000 bit remove the two 1mm screws.
  4. Coolpix S01 Zoom Trigger Replacement: paso 4, imagen 1 de 2 Coolpix S01 Zoom Trigger Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Take the needle nose tweezers to remove the black ring in the middle of the button.
    • You have successfully removed the zoom trigger and can replace with a new one if needed.
    • To reassemble follow steps in reverse.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 326
