Saltar al contenido principal
Car and Truck Wiper Blades Replacement
Chaya Milchtein
Chaya Milchtein y otro contribuidor
Última actualización: November 15, 2023
10 - 30 minutos
Fácil
Guía aportada por comunidad
Introducción
Ir al paso 1
Changing your wiper blades is a piece of cake if you follow these steps.
Qué necesitas
iFixit gana una comisión si finalizas una compra usando estos enlaces.
  1. Car and Truck Wiper Blades Replacement, Wiper Blades: paso 1, imagen 1 de 1
    • Lift your wiper blades off the windshield.
  2. Car and Truck Wiper Blades Replacement: paso 2, imagen 1 de 1
    • Cover the windshield with a towel or blanket to avoid shattering the windshield if the wiper arms come down accidentally after the blades are removed.
  3. Car and Truck Wiper Blades Replacement: paso 3, imagen 1 de 1
    • The wiper blades are typically connected to the wiper arm with a hook type of closure. Lift the plastic cover and slide the wiper backward to disconnect and carefully remove it. Repeat for the other side.
    • Unpackage your replacement wiper blades, and carefully lift the plastic cover covering the hook connector.
  4. Car and Truck Wiper Blades Replacement: paso 5, imagen 1 de 1
    • Slide the hook from the wiper arm into the wiper blade and tug slightly until securely connected. Replace the cover and repeat on the other side.
  5. Car and Truck Wiper Blades Replacement: paso 6, imagen 1 de 1
    • Remove the towel from the windshield and lower the wiper arms back onto the windshield.
    • Test the wiper blades to ensure they're securely connected and working properly.
Conclusión
When in doubt, consult your owner's manual or the back of the wiper blade package for further instructions.
Una persona más ha completado esta guía.
Chaya Milchtein
Miembro Desde 07/06/23
1,057 Reputación
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 34
Ultimos 30 días: 88
Todo El Tiempo: 790
