Saltar al contenido principal
Canon SX40 HS camera LCD Screen Cover Replacement
John Bui
John Bui y 4 otros contribuidores
Última actualización: March 21, 2018
Sin estimación
Moderado
Fotos de acción
Mejor introducción
Qué necesitas
Herramientas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  • iFixit Opening Tool
    iFixit Opening Tool
Ver más…
  1. Canon SX40 HS camera LCD Screen Cover Replacement, LCD Screen Cover: paso 1, imagen 1 de 2 Canon SX40 HS camera LCD Screen Cover Replacement, LCD Screen Cover: paso 1, imagen 2 de 2
    • Open/turn the LCD screen until it fully extends outwards.
    • Remove these two 4 mm black screws on the left side of the screen with a Phillips size #00 screwdriver.
  2. Canon SX40 HS camera LCD Screen Cover Replacement: paso 2, imagen 1 de 1
    • Partially close the screen and rotate it 90 degrees until the screen is facing upwards (photo view from the left front of the camera). Remove the 4mm black screw, indicated in the picture, with a Phillips #00 screwdriver.
  3. Canon SX40 HS camera LCD Screen Cover Replacement: paso 3, imagen 1 de 1
    • Rotate the screen 180 degrees until the monitor is facing downwards. Remove the 4mm black screw, indicated in the picture, with a Phillips #00 screwdriver.
  4. Canon SX40 HS camera LCD Screen Cover Replacement: paso 4, imagen 1 de 3 Canon SX40 HS camera LCD Screen Cover Replacement: paso 4, imagen 2 de 3 Canon SX40 HS camera LCD Screen Cover Replacement: paso 4, imagen 3 de 3
    • Using a plastic opening tool, remove the unfastened LCD screen cover from the camera.
    • Be careful not to pry and damage the circuit card under the screen cover.
  5. Canon SX40 HS camera LCD Screen Cover Replacement: paso 5, imagen 1 de 3 Canon SX40 HS camera LCD Screen Cover Replacement: paso 5, imagen 2 de 3 Canon SX40 HS camera LCD Screen Cover Replacement: paso 5, imagen 3 de 3
    • This is what you should see after removing the LCD screen cover. Replace the LCD screen cover if damaged.
Conclusión
2 personas más completaron esta guía.
John Bui
Miembro Desde 03/26/15
352 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 26
Todo El Tiempo: 1,898
