Saltar al contenido principal
Canon SX40 HS Camera Battery Door Contact Replacement
John Bui
John Bui y 8 otros contribuidores
Última actualización: December 18, 2023
5 - 10 minutos
Moderado
Imágenes Inconsistentes
Introducción
Ir al paso 1
This guide is for the replacement of the battery door contact in the Canon SX40 HS Camera (Model name 5251B001). In this guide you will be walked through the steps of removing and replacing the faulty battery door contact with a fresh one.
Battery contacts, also known as battery springs or contact springs, are strips of metal (usually with springs attached) that are placed inside of the battery compartment and assist with maintaining a constant electrical connection between the powered device and the battery's terminals. If your device will not power on, randomly powers off, or displays the screen and lights dimmer than they should be, you may have a faulty battery door contact. Ensure power to the device is properly disconnected before you begin the procedure.
For instructions on how to disconnect power, see here.
For instructions on what to do if the device's batteries are swollen, see here.
Qué necesitas
Herramientas
  1. Canon SX40 HS Camera Battery Door Contact Replacement, Battery Door Contact: paso 1, imagen 1 de 1
    • Orient the camera so that the bottom of the camera is facing up and open the battery compartment.
  2. Canon SX40 HS Camera Battery Door Contact Replacement: paso 2, imagen 1 de 1
    • Remove the two circled 2mm screws with a Phillips #00 screwdriver.
  3. Canon SX40 HS Camera Battery Door Contact Replacement: paso 3, imagen 1 de 1
    • Slide the metal battery contact away from the battery compartment cover.
  4. Canon SX40 HS Camera Battery Door Contact Replacement: paso 4, imagen 1 de 1
    • Remove the battery compartment cover from the metal bracket.
  5. Canon SX40 HS Camera Battery Door Contact Replacement: paso 5, imagen 1 de 1
    • Replace either the internal metal battery contact or external battery compartment cover.
Conclusión
John Bui
Miembro Desde 03/26/15
352 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 15
Todo El Tiempo: 910
