Saltar al contenido principal
Canon Powershot SX500 IS Motherboard Replacement
Jody Wilkerson
Jody Wilkerson y 2 otros contribuidores
Última actualización: June 24, 2015
25 minuto
Difícil
Introducción
Ir al paso 1
User will need spudger, plastic pry tool, and PH00 screwdriver.
Qué necesitas
Herramientas
  • Phillips #00 Screwdriver
  • iFixit Opening Tool
    iFixit Opening Tool
  • Spudger
    Spudger
Ver más…
  1. Canon Powershot SX500 IS Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Rotate the camera to expose the underside of the camera.
  2. Canon Powershot SX500 IS Motherboard Replacement: paso 2, imagen 1 de 1
    • Slide the rounded rectangle tab to the left to release the battery cover.
  3. Canon Powershot SX500 IS Motherboard Replacement: paso 3, imagen 1 de 1
    • Push the small orange tab forward to release the battery (Battery is ready for removal).
  4. Canon Powershot SX500 IS Motherboard Replacement, Back Cover: paso 4, imagen 1 de 3 Canon Powershot SX500 IS Motherboard Replacement, Back Cover: paso 4, imagen 2 de 3 Canon Powershot SX500 IS Motherboard Replacement, Back Cover: paso 4, imagen 3 de 3
    • Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
  5. Canon Powershot SX500 IS Motherboard Replacement: paso 5, imagen 1 de 1
    • Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
  6. Canon Powershot SX500 IS Motherboard Replacement: paso 6, imagen 1 de 1
  7. Canon Powershot SX500 IS Motherboard Replacement: paso 7, imagen 1 de 1
    • Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
  8. Canon Powershot SX500 IS Motherboard Replacement: paso 8, imagen 1 de 2 Canon Powershot SX500 IS Motherboard Replacement: paso 8, imagen 2 de 2
    • Using the plastic pry tool, remove the back cover from camera.
  9. Canon Powershot SX500 IS Motherboard Replacement, Control Dial: paso 9, imagen 1 de 1
    • Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
  10. Canon Powershot SX500 IS Motherboard Replacement: paso 10, imagen 1 de 1
    • Using the Phiillips 00 screwdriver, remove the 4mm screw to the right of the control dial.
  11. Canon Powershot SX500 IS Motherboard Replacement: paso 11, imagen 1 de 1
    • Using the spudger, lift the control dial to the right of the LCD screen.
  12. Canon Powershot SX500 IS Motherboard Replacement: paso 12, imagen 1 de 1
    • Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
  13. Canon Powershot SX500 IS Motherboard Replacement, LCD Screen: paso 13, imagen 1 de 1
    • Using spudger, lift the tab on the connector and remove the orange ribbon from motherboard (LCD screen is separated from camera).
  14. Canon Powershot SX500 IS Motherboard Replacement, Lens: paso 14, imagen 1 de 1
    • Using the Phillips 00 screwdriver remove the seven 6mm screws from the housing plate of the LCD screen.
  15. Canon Powershot SX500 IS Motherboard Replacement: paso 15, imagen 1 de 1
    • Using the Phillips 00 screwdriver, remove the 4mm mounting screw from underneath the flash.
  16. Canon Powershot SX500 IS Motherboard Replacement: paso 16, imagen 1 de 1
    • Using the spudger, lift the flash unit away from the metal housing (Flash is lifted to allow more room for metal housing).
  17. Canon Powershot SX500 IS Motherboard Replacement: paso 17, imagen 1 de 1
    • Using the spudger, remove the metal housing (Metal housing is removed from camera).
  18. Canon Powershot SX500 IS Motherboard Replacement: paso 18, imagen 1 de 2 Canon Powershot SX500 IS Motherboard Replacement: paso 18, imagen 2 de 2
    • Using the spudger, lift the tab on the ZIF connector and remove both orange ribbons connected to the green motherboard (Motherboard is lifted from camera).
  19. Canon Powershot SX500 IS Motherboard Replacement: paso 19, imagen 1 de 1
    • Remove the lens from the lens shaft (Lens is removed from camera).
  20. Canon Powershot SX500 IS Motherboard Replacement, Motherboard: paso 20, imagen 1 de 2 Canon Powershot SX500 IS Motherboard Replacement, Motherboard: paso 20, imagen 2 de 2
    • Using the plastic pry tool, remove the motherboard and the flash unit from camera frame (Motherboard and flash unit are separated from camera).
  21. Canon Powershot SX500 IS Motherboard Replacement: paso 21, imagen 1 de 2 Canon Powershot SX500 IS Motherboard Replacement: paso 21, imagen 2 de 2
    • Using the Phillips 00 screwdriver, remove the 4mm screw from motherboard.
  22. Canon Powershot SX500 IS Motherboard Replacement: paso 22, imagen 1 de 3 Canon Powershot SX500 IS Motherboard Replacement: paso 22, imagen 2 de 3 Canon Powershot SX500 IS Motherboard Replacement: paso 22, imagen 3 de 3
    • Using the plastic opening tool, lift the tab on the connector and remove the two remaining orange ribbons from green motherboard (Motherboard is removed).
Conclusión
4 personas más completaron esta guía.
Un comentario
I can't download the pictures from the camera. It doesn't have the card you take out and download the pics. I would plug it in and download from camera to my desktop. It's now saying it can't connect to the camera. I bought a new cord but it's apparently the camera itself. Any way to download the pics I have on the camera?
lfj - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 945
