Saltar al contenido principal
Canon Powershot SX10 IS LCD Screen Replacement
Qué necesitas
  1. Canon Powershot SX10 IS LCD Screen Replacement, Lithium Ion Battery: paso 1, imagen 1 de 1
    • Open the door. Release the catch by sliding it towards the side of the camera.
    • Then slide the door towards the front of the camera.
  2. Canon Powershot SX10 IS LCD Screen Replacement: paso 2, imagen 1 de 3 Canon Powershot SX10 IS LCD Screen Replacement: paso 2, imagen 2 de 3 Canon Powershot SX10 IS LCD Screen Replacement: paso 2, imagen 3 de 3
    • Remove AA batteries.
    • Using a fingernail or iFixit opening tools to pry up the battery cradle.
    • Remove CR1220 battery from the cradle.
  3. Canon Powershot SX10 IS LCD Screen Replacement, LCD Screen: paso 3, imagen 1 de 2 Canon Powershot SX10 IS LCD Screen Replacement, LCD Screen: paso 3, imagen 2 de 2
    • Remove all four screws on the corners of the screen cover.
    • Gently pry open the cover with a fingernail or iFixit opening tool.
  4. Canon Powershot SX10 IS LCD Screen Replacement: paso 4, imagen 1 de 3 Canon Powershot SX10 IS LCD Screen Replacement: paso 4, imagen 2 de 3 Canon Powershot SX10 IS LCD Screen Replacement: paso 4, imagen 3 de 3
    • Remove two screws holding on the cover plate on the pivot.
    • Remove the cover plate using an iFixit opening tool.
    • You may need to loosen the bottom first, then pry on the top of the cover plate.
    • Remove the two screws on top of the swivel arm. These two screws will be separated by the pivot point.
  5. Canon Powershot SX10 IS LCD Screen Replacement: paso 5, imagen 1 de 3 Canon Powershot SX10 IS LCD Screen Replacement: paso 5, imagen 2 de 3 Canon Powershot SX10 IS LCD Screen Replacement: paso 5, imagen 3 de 3
    • Remove grounding wire, then continue to remove the screws holding the screen and front cover plate on.
    • The screen and plate will drop after removing the last screw.
  6. Canon Powershot SX10 IS LCD Screen Replacement: paso 6, imagen 1 de 2 Canon Powershot SX10 IS LCD Screen Replacement: paso 6, imagen 2 de 2
    • Unlatch the ribbon strip and power wires from the circuit board.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 12
Ultimos 30 días: 20
Todo El Tiempo: 1,424
