Saltar al contenido principal
Canon Powershot ELPH 100 HS Memory Card Replacement
Lillia
Lillia y 5 otros contribuidores
Última actualización: January 4, 2021
5 minuto
Muy fácil
Introducción
Ir al paso 1
This guide will show you how to remove your camera's memory card when you need to transfer pictures. If the memory card is malfunctioning in any way, you can also use this guide to install a new memory card.
  1. Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: paso 1, imagen 1 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: paso 1, imagen 2 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Battery: paso 1, imagen 3 de 3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Memory Card Replacement: paso 2, imagen 1 de 2 Canon Powershot ELPH 100 HS Memory Card Replacement: paso 2, imagen 2 de 2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: paso 3, imagen 1 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: paso 3, imagen 2 de 3 Canon Powershot ELPH 100 HS Memory Card Replacement, Memory Card: paso 3, imagen 3 de 3
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
Conclusión
Lillia
Miembro Desde 03/17/15
267 Reputación
2 Guías creadas
Equipo
Un comentario
my internal card reader hardware is not functional
can i replace it somehow
s l - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 10
Todo El Tiempo: 1,113
