Saltar al contenido principal
Canon PowerShot SX600 HS Battery Replacement
Jennyfer Munoz
Jennyfer Munoz y 2 otros contribuidores
Última actualización: September 1, 2017
30 segundo - 1 minuto
Muy fácil
Introducción
Ir al paso 1
Problems with the Canon PowerShot SX600 HS camera may arise when there exists an issue with the battery, such as if its not working, placed improperly, or missing. In the guide it will show how you can replace the battery.
  1. Canon PowerShot SX600 HS Battery Replacement, Battery: paso 1, imagen 1 de 1
    • To remove the battery, locate the battery cover on the bottom of the camera.
    • Using your thumb, press down on the cover and slide it outwards.
  2. Canon PowerShot SX600 HS Battery Replacement: paso 2, imagen 1 de 1
    • Depress the orange lever holding the battery in place to unlock it.
  3. Canon PowerShot SX600 HS Battery Replacement: paso 3, imagen 1 de 2 Canon PowerShot SX600 HS Battery Replacement: paso 3, imagen 2 de 2
    • Use your fingers to remove the battery.
    • Be sure to remember the alignment of the nodes for reassembly.
Conclusión
Equipo
USF Tampa, Team S6-G4, Lacy Spring 2017 Miembro de USF Tampa, Team S6-G4, Lacy Spring 2017
USFT-LACY-S17S6G4
Miembros de 3
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 24
Todo El Tiempo: 1,554
