Saltar al contenido principal
Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement
Taylor Shields
Taylor Shields y 4 otros contribuidores
Última actualización: June 8, 2017
10 minuto
Moderado
Introducción
Ir al paso 1
The outer case of the PowerShot SD500 Digital ELPH camera is the part that takes the greatest beating. Every time the camera falls, it lands on its case. Some common problems include cracking and paint wear.
Qué necesitas
Herramientas
  1. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement, Battery: paso 1, imagen 1 de 1
    • Slide open the battery cover.
    • Push the small orange tab to the side so the battery can be removed.
  2. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: paso 2, imagen 1 de 2 Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: paso 2, imagen 2 de 2
    • Slide the battery out of the battery compartment.
  3. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement, Front and Rear Casing: paso 3, imagen 1 de 2 Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement, Front and Rear Casing: paso 3, imagen 2 de 2
    • Two Phillips screws need to be removed using a #00 Phillips screwdriver. The upper screw is under the USB port cover, which can simply be pulled away gently from the casing. the lower screw is visible on the panel.
    • The screws are different sizes. The .125 inch screw is located under the USB port cover. The 0.85 inch screw goes in the lower hole on the panel.
    • When looking at the back of the camera, these two screws are on the right panel of the camera.
  4. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: paso 4, imagen 1 de 1
    • Remove the right side cover from the camera casing.
  5. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: paso 5, imagen 1 de 1
    • Remove a .07 inch Phillips screw using a #00 Phillips screwdriver.
  6. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: paso 6, imagen 1 de 1
    • Remove two .085 inch Phillips screws from the left side of the camera using a #00 Philips screwdriver.
  7. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: paso 7, imagen 1 de 1
    • Remove the left side cover from the camera.
  8. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: paso 8, imagen 1 de 1
    • Remove three .15 inch Phillips screws from the bottom of the camera using a #00 Phillips screwdriver.
  9. Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: paso 9, imagen 1 de 2 Canon PowerShot SD500 Digital ELPH Front and Rear Casing Replacement: paso 9, imagen 2 de 2
    • Once the casing is unscrewed, hold the camera with one side facing down, and lift the opposite face of the casing to open it.
    • Remove the internal camera components and layout out all pieces on a clean surface.
    • The front and back cover may require gentle rocking to remove.
Conclusión
Taylor Shields
Miembro Desde 10/13/14
846 Reputación
8 Guías creadas
Equipo
Clemson, Team 2-1, Benson Fall 2014 Miembro de Clemson, Team 2-1, Benson Fall 2014
CLEM-BENSON-F14S2G1
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 247
