Saltar al contenido principal
Canon PowerShot SD400 Camera Case Replacement
Yi Huang Ke
Yi Huang Ke y 7 otros contribuidores
Última actualización: March 2, 2022
5 minuto
Fácil
Introducción
Ir al paso 1
This guide will demonstrate how to replace the Camera Case of the Canon PowerShot SD400.
The casing is the plastic outter shell of the camera that protects the interior components from weather and damage. Should the casing become cracked, or otherwise compromised, it is important to replace the casing as soon as possible to prevent other components from being damaged.
Qué necesitas
Herramientas
  1. Canon PowerShot SD400 Camera Case Replacement, Camera Case: paso 1, imagen 1 de 3 Canon PowerShot SD400 Camera Case Replacement, Camera Case: paso 1, imagen 2 de 3 Canon PowerShot SD400 Camera Case Replacement, Camera Case: paso 1, imagen 3 de 3
    • Remove the 6 screws holding the casing in place located on the bottom, left and right sides of the camera using a Phillips Screwdriver.
    • Be sure to save the removed screws to allow for easier reassembly.
  2. Canon PowerShot SD400 Camera Case Replacement: paso 2, imagen 1 de 2 Canon PowerShot SD400 Camera Case Replacement: paso 2, imagen 2 de 2
    • Gently separate the camera casing.
    • Once opened, the strap plate and disk pieces will also separate from the camera.
Conclusión
Yi Huang Ke
Miembro Desde 10/18/11
51 Reputación
4 Guías creadas
Equipo
James Madison, Team 1-1, Allen Fall 2011 Miembro de James Madison, Team 1-1, Allen Fall 2011
JMU-ALLEN-F11S1G1
4 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 2,002
