Saltar al contenido principal
Canon PowerShot SD30 Control Panel Replacement
Diego Hughes
Diego Hughes y 2 otros contribuidores
Última actualización: May 7, 2024
10 - 15 minutos
Moderado
Guía de Estudiante Destacada
Introducción
Ir al paso 1
Use this guide to replace the control panel in your camera.
Qué necesitas
Herramientas
  1. Canon PowerShot SD30 Control Panel Replacement, Front Cover: paso 1, imagen 1 de 2 Canon PowerShot SD30 Control Panel Replacement, Front Cover: paso 1, imagen 2 de 2
    • Be sure to remove the wrist strap and battery before removing the cover.
    • Remove the two 2mm black screws that are located on the underside of the camera.
    • Remove the two 3mm silver screws from the right side of camera.
  2. Canon PowerShot SD30 Control Panel Replacement: paso 2, imagen 1 de 1
    • Gently remove the front cover.
  3. Canon PowerShot SD30 Control Panel Replacement, Back Cover: paso 3, imagen 1 de 3 Canon PowerShot SD30 Control Panel Replacement, Back Cover: paso 3, imagen 2 de 3 Canon PowerShot SD30 Control Panel Replacement, Back Cover: paso 3, imagen 3 de 3
    • Remove the wrist strap and battery before removing the back cover.
    • Remove the 2mm screw from the back of the camera.
    • Remove two 2mm screws from the bottom of the camera.
    • Remove two 2mm screws the left side of camera.
  4. Canon PowerShot SD30 Control Panel Replacement: paso 4, imagen 1 de 1
    • Gently remove the back cover.
  5. Canon PowerShot SD30 Control Panel Replacement, Control Panel: paso 5, imagen 1 de 3 Canon PowerShot SD30 Control Panel Replacement, Control Panel: paso 5, imagen 2 de 3 Canon PowerShot SD30 Control Panel Replacement, Control Panel: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use the tweezers to pull up on the piece of black plastic connected to the ribbon to unhook and remove the ribbon connected to the screen.
    • You also have to pull up on the top part of the control panel because it is connected to the metal by a sticky pad.
  6. Canon PowerShot SD30 Control Panel Replacement: paso 6, imagen 1 de 3 Canon PowerShot SD30 Control Panel Replacement: paso 6, imagen 2 de 3 Canon PowerShot SD30 Control Panel Replacement: paso 6, imagen 3 de 3
    • Turn the camera over to the side with the lens and remove the ribbon on the left side.
    • After removing the ribbon there will be a second ribbon to remove that was hiding underneath the first ribbon.
  7. Canon PowerShot SD30 Control Panel Replacement: paso 7, imagen 1 de 1
    • Lift up the button that connects to the power button of the camera so you can remove the control panel.
  8. Canon PowerShot SD30 Control Panel Replacement: paso 8, imagen 1 de 1
    • Remove the control panel from the camera.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 7
Todo El Tiempo: 259
