Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Canon PowerShot SD1100 IS Top Button Assembly Replacement
Qué necesitas
    1. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: paso 1, imagen 1 de 2 Canon PowerShot SD1100 IS Top Button Assembly Replacement, Front and Rear Cover: paso 1, imagen 2 de 2
      • Remove wrist strap and battery.
      Pregunta a FixBot
      Agregar Comentario
    2. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 2, imagen 1 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 2, imagen 2 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 2, imagen 3 de 3
      • Remove 2 screws from each side of the camera (4 total, 0.102 in).
      • Remove 2 screws from the bottom on the camera (0.138 in).
      • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
      Pregunta a FixBot
      Agregar Comentario
    3. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 3, imagen 1 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 3, imagen 2 de 3 Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 3, imagen 3 de 3
      • Gently pull off the front cover.
      • The plate on the side should come off.
      • Gently pull off the back cover.
      Pregunta a FixBot
      Agregar Comentario
    4. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 4, imagen 1 de 1
      • The cases should now be removed.
      Pregunta a FixBot
      Agregar Comentario
    1. Canon PowerShot SD1100 IS Top Button Assembly Replacement, Top Button Assembly: paso 5, imagen 1 de 1
      • Use the spudger to disconnect the black tab.
      Pregunta a FixBot
      Agregar Comentario
    2. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 6, imagen 1 de 1
      • Gently pull off the shutter button assembly.
      Pregunta a FixBot
      Agregar Comentario
    3. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 7, imagen 1 de 1
      Herramienta utilizada en este paso:
      • Use the tweezers to disconnect the microphone cable.
      Pregunta a FixBot
      Agregar Comentario
    4. Canon PowerShot SD1100 IS Top Button Assembly Replacement: paso 8, imagen 1 de 1
      • The shutter button assembly should now be removed.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Una persona más ha completado esta guía.
Wyatt Chan
Miembro Desde 01/05/11
235 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 3-32, Regan Winter 2011 Miembro de Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
Miembros de 3
96 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 34
Ultimos 30 días: 60
Todo El Tiempo: 2,634
