Saltar al contenido principal
Canon PowerShot SD1000 Flash Unit Replacement
Phillip Phung
Phillip Phung y 13 otros contribuidores
Última actualización: June 10, 2022
5 minuto
Moderado
Necesita mejores imágenes
Introducción
Ir al paso 1
If your Canon Powershot SD1000 has a broken or faulty flash unit, use this guide to remove and replace it.
A faulty flash unit may have a weak discharge, resulting in a dimly lit photo or failure to discharge entirely.
The flash unit of the Canon Powershot SD1000 is built into the main body of a camera, and will require disassembly of the main body.
Before using this guide, check the function settings of your camera to find what mode the flash is set to. Oftentimes, when set to "Auto," the flash will not discharge.
Qué necesitas
Herramientas
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
  1. Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: paso 1, imagen 1 de 2 Canon PowerShot SD1000 Flash Unit Replacement, Back Panel: paso 1, imagen 2 de 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Flash Unit Replacement: paso 2, imagen 1 de 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Flash Unit Replacement: paso 3, imagen 1 de 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Flash Unit Replacement: paso 4, imagen 1 de 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Flash Unit Replacement: paso 5, imagen 1 de 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Flash Unit Replacement, Front Case: paso 6, imagen 1 de 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Flash Unit Replacement: paso 7, imagen 1 de 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Canon PowerShot SD1000 Flash Unit Replacement, LCD Screen: paso 8, imagen 1 de 1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Canon PowerShot SD1000 Flash Unit Replacement: paso 9, imagen 1 de 2 Canon PowerShot SD1000 Flash Unit Replacement: paso 9, imagen 2 de 2
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Canon PowerShot SD1000 Flash Unit Replacement: paso 10, imagen 1 de 1
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Canon PowerShot SD1000 Flash Unit Replacement: paso 11, imagen 1 de 2 Canon PowerShot SD1000 Flash Unit Replacement: paso 11, imagen 2 de 2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Canon PowerShot SD1000 Flash Unit Replacement: paso 12, imagen 1 de 3 Canon PowerShot SD1000 Flash Unit Replacement: paso 12, imagen 2 de 3 Canon PowerShot SD1000 Flash Unit Replacement: paso 12, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
  13. Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: paso 13, imagen 1 de 2 Canon PowerShot SD1000 Flash Unit Replacement, Flash Unit: paso 13, imagen 2 de 2
    • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
  14. Canon PowerShot SD1000 Flash Unit Replacement: paso 14, imagen 1 de 1
    • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
  15. Canon PowerShot SD1000 Flash Unit Replacement: paso 15, imagen 1 de 1
    • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
  16. Canon PowerShot SD1000 Flash Unit Replacement: paso 16, imagen 1 de 2 Canon PowerShot SD1000 Flash Unit Replacement: paso 16, imagen 2 de 2
    • Pull the flash assembly forward out of the camera to remove it.
    • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
Conclusión
Una persona más ha completado esta guía.
Phillip Phung
Miembro Desde 01/19/12
651 Reputación
9 Guías creadas
Equipo
Cal Poly, Team 8-18, Maness Winter 2012 Miembro de Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 10
Ultimos 30 días: 31
Todo El Tiempo: 3,445
